03-22-2017, 08:31 AM | #1101 | |
Re: My 50 roadster pickup build
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-28-2017, 07:47 PM | #1102 |
Well back for a little update. Last week was one of those where life gets in the way, so nothing was done.
Today I was able to work on the Hood latch panel for a couple hours. The panel was bent in a couple places in the accident, which cause several large cracks in the paint. Pic 1 overall shot of panel with cracked paint removed. Pic 2 and 3 are close ups...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 03-28-2017 at 11:20 PM. |
03-28-2017, 07:56 PM | #1103 |
Pic 1 Areas were DA'd to feather in the edges, and then the rest of panel was sanded.
Pic 2 &3 again are close ups. Will see how things go tomorrow for anymore updates...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 03-28-2017 at 11:21 PM. |
03-28-2017, 08:51 PM | #1104 |
Good to see the updates Jim. Looks like you are able to straighten the panel?
03-28-2017, 10:23 PM | #1105 |
Looking good Jim...Things always look worse before they can look better. The repair is looking top notch.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-28-2017, 11:14 PM | #1106 |
Thanks Doug, Yes I had about 30 to 40 mins of hammer and dolly work. Had to reshape the panel to match the long curve of the fender. Plus had to remove a big goosebump from where the cruise unit hit the panel...Jim
03-28-2017, 11:16 PM | #1107 |
Thanks Marc, if I can get some small things done, it will seem like I'm doing something...Jim
03-29-2017, 08:41 PM | #1108 |
Good job with the hammer and dolly.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-29-2017, 11:01 PM | #1109 |
03-31-2017, 07:41 PM | #1110 |
Got a couple small things done the last few days. On Wednesday I used some fiberglass filler to fill behind the new headlight bucket and fender. It filled most of the opening. Thursday nothing. Today I put some regular filler by the bucket again. I don't want any area were dirt and water can cause it to start rusting.
Pic 1 Filler installed Pic 2 Here I've been sanding it down. Pic 3 Covered with encapsulator paint.
03-31-2017, 07:47 PM | #1111 |
Pic 1 Also today I install filler around the headlight area and the fender.
Pic 2 and 3 showing sanding the filler. Pic 4 and 5 showing the good right fender and the look. Need to match the left to the right fender. On page 43 post #1071 you can see how it needs to be built up at the bottom to have a smooth look...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 03-31-2017 at 07:57 PM. |
03-31-2017, 09:02 PM | #1112 |
I think this type of repair is the toughest.
Matching custom work and remembering how you did it the first time so it comes out the same. Very Nice!
53 Chevy Pickup |
03-31-2017, 09:46 PM | #1113 |
Ya trying to match is hard. Where do the wires go into the bucket? or are the lights wireless
03-31-2017, 10:30 PM | #1114 |
Slow and Steady Jim- You'll make it Soon!
03-31-2017, 11:19 PM | #1115 | ||
Yes it is tough. After I did the bondo on rear of bucket, I remember that I used a body hammer to knock down the metal toward the bucket and it didn't take that much. This was about 13 yrs ago and I slept a few times since then.. Lower, wires go in from the back of bucket, haven's drilled the hole yet, wire-less lights, that's a good ideal. Ray, slow and steady, well slow at least, that's me...Jim
04-01-2017, 03:10 PM | #1116 |
Well, I got out into the shop this morning for a few hours. Installed the inner and outer fender. Aligned most of the areas I needed. Looks to be ok for now. Still need to make some adjustments. I did take my 6" aluminum rule to check how the front lined up.
Pic 1 Looking across both fenders, everything to this point is good. Pic 2 and 3 are close ups of each fender and rule. Inner and outer edge of both headlight buckets are touching so it is good. I also brought up my grill to check on the fit, let's say for an hour and a half, I messed with it, and it's going to have to been fine tuned. Didn't take any pics of this, but tomorrow I hope to get back in shop, show what's not right and make some changes...Jim
04-01-2017, 06:41 PM | #1117 |
Checking fender alignment / fit with a long straightedge is something I've never thought of before. One more idea I've learned from you Jim that is in my ideas bag now....if I can remember it. Thanks Jim!
04-01-2017, 08:30 PM | #1118 |
Looking good.
Kim |
04-01-2017, 09:20 PM | #1119 |
Dang, you mean the headlight buckets are suppose to be aligned? Heck, I thought both in the same general direction was great. You obviously work at a higher detail level then I.
Looks great Jim, keep up the good work. Rob
My '47 C.O.E build |
04-01-2017, 10:21 PM | #1120 | |
Ray |
04-01-2017, 11:09 PM | #1121 |
Thanks Doug, I saw this somewhere a long time ago, and have used it several times...Jim
04-01-2017, 11:11 PM | #1122 |
Thanks Rob, appreciate you checking it out. You camper is coming along nice...Jim
04-01-2017, 11:12 PM | #1123 |
Thanks Kim, how's the back, hope you've been doing a little on yours...Jim
04-01-2017, 11:14 PM | #1124 | |
04-02-2017, 09:13 AM | #1125 | |
Weather has been good so I'm able to spray again. Been doing a ton of sanding. No fun but necessary. Kim |
