03-18-2017, 08:07 PM | #1 |
standalone harness length question
I decided I am going with a Speartech standalone harness for my swap. I think I am going to mount the pcm in the cab, either under or behind the seat. How much extra length should I have added to my harness to get it there? I'm not sure where the "standard" length is set up to reach.
Thanks!
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
03-18-2017, 10:49 PM | #2 |
Re: standalone harness length question
6 years ago i installed a painless stand alone harness and paid $50.00 extra for 5 extra feet. My gm pcm sits behind the bench seat. I drilled a 1" hole on the passenger side of the firewall to hump area for the harness and ran it under the carpet and worked very well. The fuse /relay box is behind the seat also!
03-18-2017, 10:56 PM | #3 |
Post Whore
I would definitely go with it mounted under or behind the seat..I used psi harness on my last swap and they have a standard 4.5ft from the passenger side head..I was told they do custom lengths but when I talked to them the other day they informed me all they do is a standard length..but did say they are coming out with a builder series harness that you build yourself..if painless does custom length i will go with them as well on my 53 ls3 build but ill run it over the top of the trans and come up under the seat..
03-19-2017, 07:58 AM | #4 |
So it looks like an extra five feet will get it where it needs to be. Thank you gentlemen.
03-21-2017, 11:21 AM | #5 |
If you call John at Speartech, He will tell you where to measure from inorder to get the computer where you want it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-21-2017, 11:32 AM | #6 |
OK Rob. Thanks. I'll give John a call when I'm ready. Still waiting to finalize what connectors I need for my fuel injectors, TB, etc...
03-21-2017, 01:53 PM | #7 | |
