Old 05-23-2011, 02:57 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question Removing Window Regualator from '67 'Burb
Having problems replacing my regualator from my 1967 Suburban.
It should be easy to remove after taking out the four screws that hold it in right?
Well its not.
The crank is stripped is why I am replacing it and having one helluva hard time removing it. Is there any specail trick I am not aware of to remove this assembly?
Thanks in adavance.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 05-23-2011, 04:21 PM   #2
vectorit
What?
vectorit's Avatar
Re: Removing Window Regualator from '67 'Burb
If you have removed all of the bolts, then the sealant has it glued on.
Give it a good twist from inside the dash with you hand on the motor, and see if you can get it to break the seal.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-23-2011, 06:40 PM   #3
C20-67_N_MO
It must be in a bind or something as I can not roll down the window at all. Hince the reason why I am replacing the regualator.
But as stated, it's stuck and GOOD.
There is no sealant holding it in place at this time so it has to be something else.
But thanks for your suggestion.
Old 05-23-2011, 07:28 PM   #4
vectorit
What?
vectorit's Avatar
Never mind my post earlier... I had my mind on windshield wiper motor, since mine is giving me fits lately. Sorry bout that cornfusion.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 05-23-2011, 09:45 PM   #5
C20-67_N_MO
Exclamation Re: Removing Window Regualator from '67 'Burb
Hey no problem I do that from time to time.
While I got your attention I noticed your sig has your 'Burb as a 1968 K20, my insurance card came back as a K15. Does that make since?
Old 05-24-2011, 08:16 AM   #6
vectorit
What?
vectorit's Avatar
IIRC the 1500 designation was used on the 1/2 ton GMC trucks, and then 2500 on the 3/4 ton GMC trucks.
The fact that it's on your title from the DMV, sounds like a mix up on the person that originally registered it?
Chris
1968 K20 Suburban
1972 K10 LWB PU
