Old 03-20-2019, 08:53 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
4L60E dead?
I have a 99 Suburban 1500 with 5.7. Driving fine on the freeway and gave it more gas to pass and instead of kick down to lower gear it acted like it went to neutral. Now Park works, all other gears are like neutral. What could cause sudden failure. Could it be outside of trans like a computer or electrical problem? Or could it only be internal like the pump broke? Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 03-21-2019, 05:25 PM   #2
YoungPup1977
Re: 4L60E dead?
Can you provide some history on the truck.... what has been done to the truck lately anything ? you checked the fluid and its nice and clean, red like ATF is suppose to be....
Any noises ? TC come loose ?
First, take the metal plug out of the bottom of the bell housing and see if the TC is loose Is it OK ?
YoungPup1977 is offline   Reply With Quote
Old 03-22-2019, 11:52 AM   #3
truckdude239
truckdude239's Avatar
Re: 4L60E dead?
Sounds like the pump let go
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-22-2019, 12:17 PM   #4
Bigdav160
Bigdav160's Avatar
Re: 4L60E dead?
It doesn't move backwards or forwards?
Your first sentence describes what happens when the 3-4 clutches let go but you should still have R 1 and 2. An input sprag going out should at least backup.
No movement at all is either no fluid, pump, torque converter or input shaft breaking <-- all highly unusual for a 4L60e
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-22-2019, 12:38 PM   #5
PDW HOTRODS
Re: 4L60E dead?
It was working fine, full of good fluid. Then instantly all gears gone. Trans still full of fluid, no external leak. Park works, no other gears. I think the pump broke. Computer is not showing any code. I was just hoping it was a sensor or computer problem.
Old 03-22-2019, 12:41 PM   #6
YoungPup1977
Re: 4L60E dead?
We can all jump in here speculate all we want but I think we should start on the easy sh@t first. Like remove the metal plug as seen in the pic provided and see if anything is obvious.
If the TC is not loose Pull one of the cooler lines off and start the vehicle. Make sure you have a catch can for the fluid. Any pressure ? This would let you know if the pump took a sh@t.
Try this and get back to all of us
Old 03-26-2019, 03:27 PM   #7
Steve Cole
Re: 4L60E dead?
I broke my pump into 5 pieces just installing the tranny. They are pretty fragile. If it is broke, go with the 10 vane pump, not the 11 or 12 vane, whichever it is. I may be wrong on vane count for both so go with the one that has lesser vanes.
Let us know what you find out.
Steve Cole is offline   Reply With Quote
Old 03-27-2019, 10:06 PM   #8
YoungPup1977
Re: 4L60E dead?
It doesn't matter if its a 10 or 13 vane pump, if you are breaking the pump when you are installing the trans its not the number of pump vanes that are weak. most likely you did not have the TC all the way seated into the trans and you tightened up the trans to the engine and broke the tabs off of the pump rotor.... was it a used unit or rebuilt unit did they warranty your mistake ?
this is no where near what the OP is experiencing.
Old 04-08-2019, 03:58 PM   #9
YoungPup1977
Had a guy tell me the same thing that you are experiencing I pulled the trans and this is what I found. Front planet Torrington bearing took a dump. Destroyed a few parts. Drop the pan most likely you have metal in the pan.
Have you checked the pump yet ? Find anything ?
Old 04-14-2019, 08:43 PM   #10
Duck1
Re: 4L60E dead?
That usually happens when the converter is not completely seated
Duck1 is offline   Reply With Quote
Old 04-15-2019, 10:20 AM   #11
YoungPup1977
Re: 4L60E dead?
The OP said he had a problem while driving, his Torque converter has been installed for a while so not sure why it would be the Converter not being seated ???????
Old 04-15-2019, 11:32 PM   #12
PDW HOTRODS
Re: 4L60E dead?
The trans had high miles on it. I got a replacement and changed it out. The old one had damaged pump ears, and some damage showing in converter notches.
We didn't take it apart, just looked as close as we could, needed it for core.
Old 04-16-2019, 10:52 PM   #13
YoungPup1977
Re: 4L60E dead?
Nice.
Did you go with a used trans on that 20 year old high miler
Thread Tools
Display Modes
