Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-11-2019, 10:45 AM   #1
southern parts
southern parts's Avatar
Sail panels, deluxe heater control , & more
Sail panels - driver quality with some scratches and dings, one screw hole broke. $75
Deluxe heater control with cables and harness , no broken levers , good knobs . $80 sold
1962 Aluminum headlight bezel, driver quality with some small dents and dings around the bottom $50
RV junior mirrors- plenty of patina, one head cracked . $75
1966 1/2 ton clip type hubcap. Rough condition $15
Gas filler neck-$30
Cowl / kick panel vents- good condition, some surface rust , gaskets still good. $60
Steel upper rad hoses-$40 ea
V8 upper rad bracket with rubber cushions -$50 sold
Glove box door. -$30
All prices are plus shipping.
southern parts is online now   Reply With Quote
Old 07-11-2019, 10:48 AM   #2
southern parts
Re: Sail panels, deluxe heater control , & more
Few more pics
Old 07-11-2019, 10:59 AM   #3
MikeN
MikeN's Avatar
I'll take the better of the two steel upper radiator hose/pipes. Will send you a PM.
MikeN is offline   Reply With Quote
Old 07-11-2019, 12:16 PM   #4
pimpston65
globetrotter65
pimpston65's Avatar
i'll take the heater control.
pimpston65 is offline   Reply With Quote
Old 07-11-2019, 12:58 PM   #5
southern parts
I will try to get some totals with shipping this evening when I get in from work
Old 07-11-2019, 03:49 PM   #6
Lokin4AReason
Lokin4AReason's Avatar
Man, been looking for some upper radiator steel tubes =/
Matk me second if it doesnt fall thru . . .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 07-11-2019, 04:04 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think he said he has two.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 Service truck build:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-11-2019, 04:46 PM   #8
southern parts
Yes , I have 2.
Old 07-11-2019, 05:07 PM   #9
chtr65
I will take the upper radiator bracket for V-8, if it is correct for 64 year. Thanks
chtr65 is offline   Reply With Quote
Old 07-12-2019, 10:14 AM   #10
southern parts
I little closer look at both steel upper rad hoses . both have some pretty bad pitting and rust, probably not worth taking a chance on
pimpston65 and chtr65 I can fit both your parts in med. flat rate boxes. sending pm`s shortly
Old 07-12-2019, 11:35 AM   #11
MikeN
MikeN's Avatar
Too bad on the upper radiator pipes, appreciate you checking them out closely.
Old 07-12-2019, 02:51 PM   #12
pimpston65
globetrotter65
pimpston65's Avatar
payment sent.
Old 07-12-2019, 02:54 PM   #13
pimpston65
globetrotter65
pimpston65's Avatar
that part of the metal rad pipe is in the rubber part of the hose, it should still work and not leak. just my 2 cents
Old 07-12-2019, 03:12 PM   #14
MikeN
MikeN's Avatar
Yeah, the one on the left doesn't look too bad, if the other end is no worse I'm still interested. PM me if you still want to sell.
Old 07-12-2019, 06:46 PM   #15
LostMy65
LostMy65's Avatar
If you decide one of the radiator pipes is beyond usable, I might be interested in trying to create a cad template from it that someone could take down to the muffler shop and have one bent out of stainless.
Old 07-17-2019, 11:00 AM   #16
southern parts
Winston, the heater control is on the way. You might even have by now.
Old 07-17-2019, 12:06 PM   #17
pimpston65
globetrotter65
pimpston65's Avatar
sure did get it,safe and sound...
Old 07-17-2019, 03:47 PM   #18
LostMy65
LostMy65's Avatar
Are both radiator pipes sold?
Old 07-17-2019, 07:21 PM   #19
southern parts
LostMy65- no, I still have one.
Old 07-17-2019, 09:54 PM   #20
LostMy65
LostMy65's Avatar
Did you say it was pretty rusted?
Would you do $40 shipped?
Old 07-18-2019, 11:05 AM   #21
southern parts
It's pitted on both ends. Let me see how much shipping will be.
Old 07-20-2019, 08:27 PM   #22
LostMy65
LostMy65's Avatar
Payment sent.
Old 08-02-2019, 09:10 PM   #23
southern parts
Bump
Old 08-04-2019, 12:16 AM   #24
bcontractor
bcontractor's Avatar
I like to see more pick of the glove box door ..shipped to 95407 ?
There is more then one way to do it right !
bcontractor is offline   Reply With Quote
Old 08-06-2019, 07:44 PM   #25
bcontractor
I will take the glove box door ,shipped to 95407
Copyright ©2000 - 2019, vBulletin Solutions Inc.
