02-18-2024, 12:52 AM | #26 |
Who Changed This?
Re: To Sniper or not to Sniper...?
Cliff doesn't personally rebuild carbs anymore, I understand that he is retired. I bought a kit from him many years ago and it worked fine. It's up for rebuild again, and that's the way I'd go. The only real adjustments a carb needs is from winter to summer and back. My take is that vehicles sitting long enough for the fuel to evaporate out of the float bowl have problems. I know mine does. But if I start it even every other day, all I have to do is pump the pedal once and turn the key until it starts, and that may be as short as turn and release. As usual, one's mileage may vary.
FWIW, given the number of miles I drive my truck per year (~1000), I don't think that I'd ever recover the installation cost, even if I provided the labor for free.
02-18-2024, 11:42 AM | #27 |
As others have already said, the main benefit of the Sniper I installed on my truck has been easy starting all year. Probably not worth the expense and effort just for that. Here a few other built-in Sniper features I like:
1) Idle RPM stays steady when the A/C kicks on 2) A/C shuts off at WOT 3) Temperature based dual electric fan control 4) Optional ignition timing control The Sniper 2 offers optional electronic automatic transmission control. |
02-18-2024, 04:17 PM | #28 |
How does the ignition timing control work? Does it require a special distributor with electronic gizmos in it, or does it control the timing by varying vacuum going to the can on the distributor? Some sort of knock sensor required?
02-18-2024, 04:33 PM | #29 |
Holley sells a distributor called the Hyperspark that is designed to work with the Sniper. It is actually a very simple distributor with no vacuum advance or mechanical advance. It just has a sensor that detects the orientation of the rotor and sends its readings to the Sniper. The Sniper adjusts the timing as it sees fit by controlling the angle at which a spark pulse is sent through the ignition system. The rotor/cap can conduct spark pulses within a fairly wide angle range (the rotor doesn't have to be perfectly aligned with the cap contacts). There is no knock sensor.
02-19-2024, 12:06 PM | #30 |
Well said. Q-jets might just be the best carbs ever.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-19-2024, 12:50 PM | #31 |
Definitely best overall street carb. For super high performance race applications, the Holley Dominator ranks highly.
Every single vintage hobby vehicle I own has a Q-Jet, and all perform well no matter the weather. You have to be good with setting them up, as well as timing and other adjustments to get great results.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-19-2024, 12:53 PM | #32 | |
Chevy Freak
67 K20 5.9 p pump cummins (in progress) 68 Camaro 454BBC 86 Camaro 5.3LS turbo |
02-19-2024, 07:22 PM | #33 |
Failed to mention in my previous post that swapping a 'lectric choke onto a q-jet can simplify things, particularly since you mention cold start problems
1970 C10 Custom longbed 350/350 |
02-21-2024, 04:31 PM | #34 |
With the price of fuel up here at $1.60+ liter some sort of fuel injection makes sense. My '72 went from 13mpg to 19mpg when I LS swapped it. I thought about the sniper before I took the plunge. I saved the 350/350 in case I ever sell it. (unlikely)..
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
