Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-18-2014, 04:40 PM   #1
PastJoysandToys
PastJoysandToys's Avatar
1964-1966 K10 Carryall 4x4 Data Tag
Wanting to replace a missing data tag (left lower kick panel) on a 1965 K10 1406 Carryall 4x4. Appears the data tag (photo below) may be available but I am not sure that this is the correct one (since mine is missing). To the best of my knowledge the 327cu. in. V-8 was not a option until 1966 ? Does any one know if this is the correct one and if not does anyone have a photo of a correct one/know where to get one. Thanks
PastJoysandToys is offline   Reply With Quote
Old 09-18-2014, 11:09 PM   #2
pimpston65
pimpston65's Avatar
Re: 1964-1966 K10 Carryall 4x4 Data Tag
i have 1965 C10 that roll out the factory in aug and it has the same trim tag and its correct, also i was told late 1965 they did have 327's come on the schene for trucks...so i think if you had a late 64 or early 65 the tag may only have the 283, maybe someone with me knowledge can chime in...
pimpston65 is offline   Reply With Quote
Old 09-19-2014, 12:13 AM   #3
PastJoysandToys
Found the one below which does not include the 327 cu. in. in the 'list' and would appear to be correct ? Hoping someone can explain the difference including which is correct for a 1965 1406 4x4 Carryall. Thanks.
Old 09-19-2014, 12:56 AM   #4
MikeS.
MikeS.'s Avatar
It's going to depend on when in 1965 yours was made. Late 65 could have had a 327 in it. I believe 66 was the first year they advertised having the 327 available. I know my last 66 truck had the 327 in it. Which I replaced with a 350 that I built for hauling a camper up-and-down the Sierra Mountains.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 09-21-2014, 09:19 AM   #5
60-66
60-66's Avatar
In 65 the 327 was only available in 3/4 ton and up, no half tons. I looked at 3 65 tags and none list the 327. But that's not to say, like Mike said, it may have been that the tag was changed late in the year. If you have any buildsheets or protecto plate we may be able to figure out when it was built.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-21-2014, 10:54 PM   #6
sodly
sodly's Avatar
I've wondered about this, too. Wasn't the same tag used on the medium duty trucks? Wasn't the 327 available on mediums prior to late-65?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 09-30-2014, 05:05 PM   #7
PastJoysandToys
There was no buildsheet or protecto plate. So, what we have done is taken a repo 1959 data tag and scanned it in to the computer since the backingplate size, letter fonts and hole placement for rivets are exact same as the 1965. Then using a photo of a 1965 and the scanned in 1959 created a 1965 without the 327 noted on the 1966. Have already contacted a printer who can do the reproduction and am waiting on printer guy to get caught up with other work (should be a week or so). Looks like we are going to print a 'sheet' of them since it appears to be much more cost effective than just the one (which means we should have a few extra to offer for sell). The photo is the 1965 id data tag we came up with (photo is blown up about x3) printed off on a plain copy paper.
Old 10-02-2014, 04:00 AM   #8
pimpston65
pimpston65's Avatar
put me in line for one...
Old 10-17-2014, 04:49 PM   #9
PastJoysandToys
Still working on finding someone that can do it (in contact with someone new at present). Did come up with another question. What is a CA # (located in the bottom right) ? Thanks
Old 10-17-2014, 06:19 PM   #10
bhc41051
bhc41051's Avatar
C.A. stands for "Cab to rear Axle"
bhc41051 is offline   Reply With Quote
Old 12-01-2014, 06:53 PM   #11
PastJoysandToys
Still working on the data tags. Sample may be ready, should know this week. Will keep updating.
Old 02-28-2015, 06:35 PM   #12
PastJoysandToys
Finally, sorry for just updating (been dealing with father's Trust and estate since his passing). On top of this the girl that was doing the data tags ended up in the hospital right before Christmas 2014 and had brain surgery. She is doing ok and made it back to work (in a wheelchair) by the end of January and was able to finish the job. As of yesterday I now have the first 40 reproduction data tags for the 1964 and 1965 Chevy C 10s and K 10s in hand (these may also fit other 1964 and 1965 models). The original data tags were screen printed where as these are produced using the sublimation printing process which is like the next grade up in quality (meaning that they are harder to scuff, scrap or scratch). The lines and lettering are crisp, even and straight due to 'reworking' the scan on the computer. The difference can be seen comparing it to the last 2 photos showing a reproduction 1955 2nd series data tag and a reproduction 1953 data tag. The tag guy, A. G. Backeast says he can stamp them as factory original. They will be listed on eBay @ $23.25/each ($2.50 shipping) but anyone from these boards can obtain one for $20.00 + $2.00 shipping. Thanks to all who had info and input.
Old 06-16-2017, 10:04 AM   #13
Roblenzz
I have a 1966 factory K10 that I am looking for an authentic ID plate, that I havent seen another like it. I printed out a pic of the example of the one you provided and hand wrote out, line for line what my original tag says. Any one have a line on one of these?
Roblenzz is offline   Reply With Quote
Old 06-16-2017, 04:05 PM   #14
PastJoysandToys
Getting ready to do 2 of the 1966 data tags also (computer guy is working on it as I write this). Should be ready in 30 to 45 days. The photos below are the ones we are doing and the one matches what you need.
Old 06-19-2017, 11:10 AM   #15
65chevysub
65chevysub's Avatar
Sorry to break in to this thread, but what size rivets would I use to re attach my data plate? I was thinking stainless screws as I'm eventually going to have the kick panels carpeted again. Thanks
Paul
65chevysub is offline   Reply With Quote
Old 06-19-2017, 04:59 PM   #16
Roblenzz
The holes are pretty large. A lot bigger than a standard rivet. Holes are like 1/4". If you're not looking for a factory look you're gonna have to go with a pretty big self tapping screw since you can't get at the back side. Search eBay for chevy truck ID plate rivet and you'll get something pretty close to factory.
Old 06-19-2017, 06:53 PM   #17
65chevysub
65chevysub's Avatar
Thanks. I will probably just go with screws since my truck isn't going back to factory.
Old 08-11-2017, 10:04 PM   #18
PastJoysandToys
The new 1966 tags are now ready. Seller ID on eBay is Past Joys and Toys.
Old 08-12-2017, 05:23 AM   #19
pimpston65
pimpston65's Avatar
now only if they made a canadian version???
