04-16-2018, 10:39 PM | #1 |
stock height 71-72 spindles powder coated almost new
PO said these Western Chassis stock height spindles have about 1500 miles on them came with some other parts I purchased, powder coated then decided to go with drop spindles
thanks jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-19-2018, 08:05 PM | #2 |
Moderator
Re: stock height 71-72 spindles powder coated almost new
I don’t believe they make 71/72 stock height aftermarket spindles...they are already disc brake spindles. I’ll bet they are stock height conversion spindles for a 60-70 truck. Check ball joints/tie rods to be sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-19-2018, 08:32 PM | #3 |
thank you you are absolutely correct i called Wester chassis sent them pics etc. here is what they are 1973-87 Chevy C10 Stock Height Replacement Spindles
1973-87 Chevy C10 Stock Height Replacement Spindles Replacement spindles for 73-87 Chevy C10, GMC C15 or Suburban. Great for disc brake conversions using late model front end on an early truck. $239.00 So they can be used on 67-72 but depending on what year ball joints and inner and outer tie rods need to be changed ill most likley put them on for a reasonable $ and take something reasonable to move them off my shelf thanks Again Jess
