10-30-2018, 07:18 PM | #1 |
Volt gauge in dash
I've got this volt meter gauge in the dash that is not reading what I expect. It's consistently reading around 12 volts when I observe nearly 13 volts both at the battery and at the single wire alternator.
This occurs with the engine running and all major electrics operating ( including dual electric fans, relay operated headlights and blower fan on high ). I would rather the gauge read true. Any ideas? Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
10-31-2018, 09:54 AM | #2 |
Msgt USAF Ret
Re: Volt gauge in dash
This is a fallacy of one wire alternators and is why I never recommend them over the standard three wire units.
In order to supply the required voltage for all the electrical needs of the truck's circuits, the alternator's internal regulator needs to sense the downstream voltage drops in the systems circuits. With the one-wire alternator the internal regulator senses the voltage at the charge wire connection. It is important to have the charge wire connection at the main harness junction. Most installers make this connection directly to the battery's positive post. In your case you should make the charging connection at the terminal junction where you have the biggest current draws, I.E. electric fans and cab supply junction. Have you read the voltages with a multi-meter? The biggest problem could simply be that the alternator doesn't have enough output to supply the 14.2 volts that you need at 1500 rpms.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-31-2018, 02:56 PM | #3 |
The big electrics draws under the hood: dual rad fans, ignition, fuel pump, EFI, headlamp relays, etc... are fed directly from the alternator charge wire.
Whether the AC blower fan and the main harness to the cab is fed from there is questionable. Upon cold start measuring with a multmeter I get 14.1 at the alt and 13 at the battery with the dash gauge reading just over 13. Once coolant reaches 195 and both fans get full power, nothing else extra running I get 13.35 at the battery and 13.70 at the alt with the inside gauge reading 13. Next cycle of the fans I added lights on high beam and the numbers were: 13.30 battery 13.60 alt 12.8 gauge Next cycle on of the fans I add full power on the cab AC blower fan: 13.05 battery 13.35 alt 12.5 gauge Just flicking on the lights with no fans or blower motor 13.70 battery 13.80 alt 12.9 gauge All this was done at idle of about 750-800 rpm. Bring RPMs up to 1500 or so did not change the position of the gauge needle when under load. However I did notice the engine RPMs drop slightly when the fans kick on and the gauge did seem to recover immediately after with a bump up after the initial "hit" on voltage so I think the alt is sensing the voltage draw. Interesting to me was that I was able to produce more of a gauge drop with the cab AC fans than the much more robust and demanding radiator fans did when they kicked on. This is likely due to the wiring of the gauge being much closer to the draw given that the gauge doesn't really seem to be reflecting what is actually happening under the hood anyways. -klb
10-31-2018, 11:58 PM | #4 |
Msgt USAF Ret
All your readings suggest that the alternator output amperage is not sufficient for the current loads that you have. While they are keeping up with the current draws, you could use a higher current alternator. What amps alternator do you have installed. For your loads a 100 amp should get the job done.
11-01-2018, 06:03 PM | #5 |
My alt is a CS 130 style unit. Best I can tell is it's about an 80 or 90 amp.
I found the main ground from the battery to frame was not tight! Ran the tests again today but it was too cold out for the fans to kick on during the time frame I had. The results were better... Readings in volts: alt/battery/gauge 14.20/14.05/13.3 cold start 14.12/13.98/12.9 added full high AC fan motor 14.00/13.85/12.6 added High beams my guess is if the fans kicked on the readings would be 13.50/13.10/12 Still don't like the gauge reading so far off from actual though. -klb
