11-28-2017, 04:58 AM | #26 |
Re: My 57 Chevy #2 with PB Fab frame & RideTech Coilovers
-Chuck
I was looking at a post that you made in the shop area, to use a standard outlet for the ceiling fixture due to the every evolving lighting fixtures. I'm in the final states of building my shed, I'm going to use your wisdom for my ceiling lighting. Thanks New build looks like fun. Keep on keepin on NC
Been there, wrecked that |
11-28-2017, 04:14 PM | #27 | |
11-28-2017, 07:09 PM | #28 |
Nice powder coated stuff. After I was to far along I found the PB stuff. If I do it again thats the way I'd go.
My 55 Build 55 C-4 |
11-28-2017, 11:38 PM | #29 | |
A320 Pilot/USAF Retired
I don't remember making a post over there, but glad it helped.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-05-2017, 03:47 PM | #30 |
I knew you had two frames, now I see you bought an extra truck...
Surely I will follow this one too!!! Gonna be fun!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-10-2017, 12:48 AM | #31 |
Can't wait to see more on this one!!
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
03-21-2018, 09:47 PM | #32 |
Haven't posted in awhile, but here's an update. Picked some scrap I-beam and made a level welding table to mock up the frame. With it all squared up it will be completely welded up solid. I will probably weld up most of the bolt holes afterwards just to clean up the look a bit.
03-21-2018, 11:20 PM | #33 |
Welding table is definitely the way to go, if i ever do another that will be the first thing to get done. looks like the start of another awesome truck.
My taking way longer than expected 58 build |
03-21-2018, 11:37 PM | #34 |
Good ideal with the welding table, going to be a super nice frame...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-22-2018, 07:31 PM | #35 |
Dang Chuck, you are serious about this one, LOL. SCRAP I-beams??? Who throws straight non rusted steel like that away?
03-22-2018, 11:16 PM | #36 |
Excellent. Definitely going to steel that idea for my next build.
03-23-2018, 03:07 AM | #37 |
Wow that "welding table is fandamtastic!!!! Good get on the I-beams.
How many friends will it take to move it? Or are you just going to radiate yourself, turn green and do it alone? NC
03-25-2018, 02:16 PM | #38 | |
Thanks guys!!
05-21-2018, 12:41 PM | #39 |
Well here's an update for you guys!
I had a pro welder come to my house and weld everything up after I squared everything up and tacked it together. Decided to remove the bolts and weld up the holes to make it look a little cleaner. This week I was finally able to put in some serious garage time and make it a roller, sort of a roller, don't have any wheels to fit the front hubs! The RideTech coil over shocks are very nice, hope they perform half as good as they look! Hope to keep up this pace over the summer! Next is to install a mockup motor and trans and build the exhaust and run the fuel and brake lines.
05-21-2018, 12:43 PM | #40 |
1 more!
05-21-2018, 01:05 PM | #41 |
That’s looking great
05-21-2018, 07:08 PM | #42 |
Wow, very nice!
05-21-2018, 07:32 PM | #43 |
Way to go JJ, very nice work...Jim
06-25-2018, 09:50 PM | #44 |
Bolted in a mock-up motor and trans, rolled her outside to check out the stance, I like it!!
06-25-2018, 11:14 PM | #45 |
Looking good JJ...Jim
06-26-2018, 12:11 AM | #46 |
EVerything's looking good, JJ.
You'll probably lose 50% of the remaining space between the top of that Coke can and the underside of the frame just by putting the bodywork on.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
06-29-2018, 12:06 PM | #47 |
looks good, i like it. any chance i could get a few measurements?
06-30-2018, 08:33 PM | #48 | |
11-21-2020, 02:20 AM | #49 |
Last Post from JJ ChuckDriver was on 6.30.2018
Where are you JJ ?
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
11-21-2020, 09:15 PM | #50 |
Yes it has been a long time since I posted anything on this site. Lots of things have happened in my life that slowed any progress on my truck projects. The worst thing was the untimely passing of my wife in Feb 2019. It has been a major adjustment for me and my children, but we are doing pretty well all things considered.
At the urging of my children, I bought a new home to help with the healing process. The plus side is its a raised home with 1800 sqFt of garage space. This summer my son and I did get to work on a few other projects. I do hope to get going again on the PB frame build. Here's a peak at what we have been up to.
