Old 10-11-2018, 09:27 AM   #1
Slammed96
Floor repair
I've been doing a lot of reading on replacing floors/rockers/cab corners on here lately and noticed that the vast majority of writeups involve having the cab off of the truck. Aside from the obvious ease of access and space, is there any disadvantages to doing these repairs with the cab on the frame? I'm limited on space, so it will be less hassle to leave the truck mostly assembled. I plan on going slow and doing one smaller section at a time so I don't have to worry as much about the cab flexing or tweaking.
05 Silverado- 3/6 drop, 212/218 cam, full bolt on low daily.
66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop in the works.
Slammed96 is offline   Reply With Quote
Old 10-11-2018, 10:31 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Floor repair
Just depends on how much floor you need to repair, if its just outer area then no need. I pulled mine but only because I did a frame off.
LT1 Burb is offline   Reply With Quote
Old 10-11-2018, 11:44 PM   #3
66C10LB
Re: Floor repair
Maybe check the front cab mount area carefully. If there is significant pitting on the curved bracket that covers the body mount bolt, then there may be damage to the inside of the floor brace within this area. It may be wise to lift the cab to repair in this case.
66C10LB is offline   Reply With Quote
Old 10-12-2018, 06:31 AM   #4
Slammed96
Re: Floor repair
I'll give it a good once over before I begin. Truck has been from southern states it's whole life, so the rot isn't nearly as bad as many I've seen.
Old 10-12-2018, 10:00 PM   #5
'65 chevy lover
Re: Floor repair
Regardless if you go slow, just make sure to put in bracing. It don't take a lot of movement to screw things up.
'65 chevy lover is offline   Reply With Quote
Old 10-12-2018, 10:20 PM   #6
Slammed96
Re: Floor repair
Even with the cab still bolted in place? I also plan on leaving one door hung and closed at a time while I work on the opposite side.
Old 10-12-2018, 10:24 PM   #7
'65 chevy lover
Re: Floor repair
I think so. It's good insurance. There may be others that would say no. I say better safe than sorry.
Old 10-12-2018, 10:27 PM   #8
Slammed96
Re: Floor repair
Fair enough. Easier to remove a few braces than in tweak a cab lol.
Old 10-13-2018, 12:20 AM   #9
'65 chevy lover
Re: Floor repair
Yes sir!
Old 10-13-2018, 08:55 AM   #10
LT1 Burb
LT1 Burb's Avatar
Re: Floor repair
I wouldn't bother with bracing, unless you removed the entire floor or roof.
Old 10-13-2018, 01:12 PM   #11
61K10
61K10's Avatar
Re: Floor repair
Leave it on the frame and bolted down. Do one side at a time. This is how i did mine, no braces and i replaced inner and outer rockers and bottom of pillars and rear door frame bottom. I had all door measurements of door openings to make sure nothing moved. A little bracing hurt though.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
