Old 10-12-2018, 12:12 AM   #1
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
GMC 270 engine mystery.
I have a '48 GMC 300 series truck. The
motor has been replaced with a 270.
GMC engine serial numbers are hard to come by/interpret. Here is the only block number I can find.
Can anyone help ID so I can maybe figure out what parts I need to order. Thanks.
From what I have read, they made a couple of different types of 270's over the years.
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 10-12-2018, 07:58 AM   #2
1project2many
Re: GMC 270 engine mystery.
I've never searched for an old GMC engine number before. It looks like the first three digits designate the engine as a 270. I believe the second three digits are a serial number. I believe I 4 I would be where a date code is found, and that the format should follow the same format as the casting date codes. If so, that the second I should be a number.
Lastly, here is another helpful bit of information on reading date codes from Andy Siechen, our GMC Engine Technical Advisor: Several people have asked here and through my email about how to tell what year an engine really is. Here goes: I attached a picture of what is used to determine the casting date of the GMC engine blocks and heads.
The first digit is always a letter of the alphabet A-L. A=January, B=Febuary, C=March etc, etc all the way to L=December. The next digit is a number 1-31 which is the day of the month. The last digit is always a single number and represents the year of the casting.
So unless the I is a 1, which would indicate a '51, we have a genuine mystery.
My suggestion is to look for the casting dates on the block and head using the following reference:
The date code casting for the block is usually on the same side if the block as the casting number. The cylinder head location is usually outside the valve cover near the center. Some of the later 270 and 302 heads had all the casting numbers and date castings under the valve cover down near where the pushrods come through. The raised area with the date almost looks like a small plate attached with two screws and they are often mistaken for something that can be removed. They actually are part of the casting.
Good luck in the search.
1project2many is offline   Reply With Quote
Old 10-12-2018, 04:59 PM   #3
rustycars63
There is a GMC old trucks web site that can help you with identify of your block.
rustycars63 is offline   Reply With Quote
Old 10-12-2018, 05:50 PM   #4
mr48chev
mr48chev's Avatar
The Old GMC site doesn't show engine numbers that I can find. http://www.oldgmctrucks.com/index.html
I did find this with casting numbers http://home.znet.com/c1937/Cast.htm
My ongoing truck projects:
Copyright ©2000 - 2018, vBulletin Solutions Inc.
