Old 02-05-2011, 09:09 PM   #1
swamp rat
swamp rat's Avatar
Crank Bolt size.
I need to know the "socket" size for a front crank bolt for a Big block and small block chevy, i beleve the small block is 9/16 by memory but could be wrong, Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-05-2011, 10:33 PM   #2
clinebarger
Re: Crank Bolt size.
SBC takes a 5/8" socket, BBC takes a 15/16" socket.
clinebarger is offline   Reply With Quote
Old 02-05-2011, 11:11 PM   #3
swamp rat
swamp rat's Avatar
Thank you!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-06-2011, 12:47 AM   #4
Captainfab
60-66 Nut
Ummmm I would say a BBC uses a 3/4" socket since it is a 1/2" bolt. Maybe 13/16" at the most......it's been a while since I've had a BB balancer bolt out.
Old 02-06-2011, 04:03 AM   #5
swamp rat
swamp rat's Avatar
Ok thanks, i just don't want to pack the whole set..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-06-2011, 09:29 AM   #6
Lee H
Lee H's Avatar
Also keep in mind after market, such as ARP or Moroso, are different sizes.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-06-2011, 05:25 PM   #7
60ratrod
yes, i do
60ratrod's Avatar
at least you weren't trying to figure out the shank size and thread pitch. its quite an odd ball with shank size and pitch
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 02-06-2011, 06:53 PM   #8
clinebarger
I just installed a 396/TH400 in a 65 Impala SS, The bolt had a 15/16" head & a 9/16" thread I guess it was drilled out?
Old 02-07-2011, 12:34 AM   #9
Captainfab
60-66 Nut
That could be if someone stripped out the original threads. I just went out to my Suburban and checked.....3/4" socket fits.
Old 02-07-2011, 12:36 AM   #10
swamp rat
swamp rat's Avatar
Or different cranks, stock and aftermarket? Its no problem anymore guys, thanks for the help!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-29-2018, 06:37 PM   #11
TBone1970
Hi All,
Do any of you know the thread size of the bolts that are used on the actual crank where it connects to the flexplate on a 402BBC?
Thanks in advance.
70 CST C20
TBone1970 is offline   Reply With Quote
Old 09-29-2018, 11:52 PM   #12
Captainfab
60-66 Nut
They are 7/16"-20. Just be sure you don't use bolts for a flywheel as they are too long and will ruin your block if you run it that way.
Old 09-30-2018, 12:05 AM   #13
Chevyrestorerman
Flexplate bolts are shorter than the "flywheel" (manual trans) bolts, they both are the same size but the flexplate bolts are shorter, the longer bolts if used on a flexplate will come into contact of the block and rear main cap causing issues you do not want.
Chevyrestorerman is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
