Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-22-2018, 04:25 PM   #1
65truckowner
65truckowner's Avatar
all fuses hot with battery hooked up 65 c10
I am almost done with my 65 restoration so today I put a battery on it to check out the wiring and all the fuses are hot like the switch is on. So I unplugged the switch and the same thing. All the wires coming to the switch are hot except the one going to the start side of the starter. What do I need to check. This is a 1965 c10
65truckowner is offline   Reply With Quote
Old 09-22-2018, 08:16 PM   #2
franken
Re: all fuses hot with battery hooked up 65 c10
And what have you done with the wiring during the restoration?
franken is offline   Reply With Quote
Old 09-22-2018, 08:37 PM   #3
65truckowner
Nothing it was set aside then retaped and reused. I thought maybe the switch was bad but I unplugged it with the same result. I unplugged the harness at the firewall and 2 of the 5 wires where hot
Old 09-23-2018, 09:49 AM   #4
65truckowner
any one have a picture of the horn relay, voltage regulator wiring on there 64-66
Old 09-23-2018, 06:16 PM   #5
65truckowner
found a wire someone had added for some reason and cut it now all works like it should
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
