Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-05-2018, 04:40 PM   #1
Defector
Front marker question
1969 C10, recently resurrected after sitting for 10 years or so. Ran into some grounding issues with some lights, but have a weird issue with the left front marker light.
1. In hazard or blinker, it is not as bright as the right, making me think it's a ground issue. Cleaned the ground on the radiator mount, right behind the marker light, no better.
2. With lights turned on the market doesn't light at all, and the left turn indicator on the dash remains lit.
3. No left turn signal with the lights turned on.
I did replace the bulb. My next move is changing out the housing assembly.
Any other ideas?
Defector is offline   Reply With Quote
Old 10-05-2018, 08:36 PM   #2
Longhornss
Re: Front marker question
Any other ideas?
Everything you are describing sounds like a ground issue to me. Use some scotch pad and scrub the bulb socket. you could also try running a secondary ground wire directly to the housing.
Longhornss is offline   Reply With Quote
Old 10-05-2018, 09:45 PM   #3
Defector
That's a good idea. I'll run a new ground.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
