01-23-2018, 11:47 PM | #1 |
lowering
I took the rear shackles off to drop the rear so the truck was closer to level.
If I wanted to drop the truck a little more is it possible without replacing spindles or any other major work? Just a little lower, maybe an inch, or 2" max.
1993 Silverado, 305, auto, short bed |
01-24-2018, 03:17 AM | #2 |
Re: lowering
Your choice to lower the front is as follows:
Lowering springs - 2” Dropped spindles - 2-2.5” DJM tubular control arms - 2” Remember these year trucks had kits that dropped them: Front/Rear 2/4 4/6 - requires c-notch and under bed trim above pumpkin 5/7 - same
Customization is what you want it to look like -- not what other people think it should look like |
01-24-2018, 04:42 PM | #3 |
driving is in my blood
Re: lowering
Lowering springs are availalbe in more then just 2", namely 1" and 3" drops as well. I never found any 2.5" drop spindles for this gen truck either.
OP- so you lowered the rear some, are you asking about rear only or the entire truck down 1-2" more now?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-24-2018, 04:53 PM | #4 |
Re: lowering
"OP- so you lowered the rear some, are you asking about rear only or the entire truck down 1-2" more now? "
Lower the entire truck another 1" or so. It is currently fairly close to level so I would want to drop it an equal amount front and rear.
01-25-2018, 03:57 PM | #5 |
Re: lowering
Rear you can do the leaf spring front mounts known as hangers, or get lowered leafs. Front I'd just get some new springs, they don't make 1" spindles.
