Old 02-01-2018, 11:08 AM   #1
GMC85HighSierra
GMC85HighSierra's Avatar
94 GMC Sierra Parts On An 89 Crew Cab
Hi all, I have a couple questions on an 89 Chevy crew cab and a 94 GMC Sierra.
1. My dad has a 1989 Chevy crew cab I'm thinking about getting, and I was wondering if a steering column out of a 1994 GMC Sierra will work in it. I'm not sure if the 89 has a tilt steering column, but I know for sure the 94 column does. From what I can see, it looks like they're pretty much the same (except for the tilt lever and the shifter).
2. Will the AC components from the 94 work on the 89? I know the AC works in the 94, but not sure about the 89.
3. Will the 350 engine with the serpentine drive out of the 94 work with the 89? The engine runs good, and the one in the 89 has been sitting for a while (so not sure on it).
Basically I'm asking if the parts will be plug and play, or if I'll have to do some modifying to make the parts work.
The reason I'm asking all of this is because I have a 94 GMC that needs a bunch of body work, a new trans, and some other things. Was thinking about parting it out and putting some of the parts to use. Thanks
GMC85HighSierra is offline   Reply With Quote
Old 02-01-2018, 02:27 PM   #2
D13
D13's Avatar
Re: 94 GMC Sierra Parts On An 89 Crew Cab
Assuming the 89 is a square body and the 94 is a GMT400:
1. no.
2. no, except the compressor if swapping the engine.
3. Yes, with some thought. You may have to swap sensors to match the inputs the earlier ECM was looking for, and the fan to radiator shroud will have to be looked at, and the exhaust manifolds 'might' need to be swapped. PS hoses and such 'should' be OK, unless the crew has hydroboost. Cruise set up is differnet, and a bazillion little things like wire lengths, starter / flexplate/trans, etc. But the basic motor should swap.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-02-2018, 12:31 AM   #3
hatzie
Moderator
hatzie's Avatar
1) It's not likely to be a DROP IN deal...
Likely you could use the 94 column... It is a Saginaw column just like the 1989. Folks mount Caddy tilt/telescoping columns in other cars and trucks... not just GM vehicles either.
Carefully pull em both out and lay em both side by side where you can easily look em over.
Are they the same or close in length? 1/2" - 1" is not the end of the world. The distance that's most critical is the wheel to the under mount. Slightly shorter or longer through the firewall isn't hard to deal with... Think XJ Jeep U-Joint steering shaft... Google it.
The firewall plate can be swapped as needed. The hot rod boys do it all the time.
You'll likely find the under mount is in an OK position or can be moved without a major hassle.
The steering wheels are interchangeable between the squares and the 88-94 T400 series columns pick the one you like and run it.
Wiring is the one that scares most folks... OOOGIE BOOGIE I'm so afeard... Do some planning on paper. Get some Delphi or SIR Tools terminal extractors and print out the wiring diagram pages to take notes on in pencil. The nice thing about the 11x17 Tabloid PDF pages is you can have the printer at FedEx Office scale em up to 12x18 ARCH-B. It's surprising what a difference 1" in both directions makes.
I'd be willing to bet GM used the same connector families if not the same connectors on both columns. Worst case you can adapt the 94 column pigtails to mate with the 89 wiring by swapping connectors on the column or cab harness as needed.
The 94 T400 Backup/Neutral-safety switch should plug right into the 89 RV series wiring.
The ignition switch probably is the same. A cursory glance at the wiring diagrams tells me that both the 89 RV and the 94 CK ignition switches mate with Delphi 12010966 & Delphi 6294641 plugs on the cab harness side. Look over the wiring diagrams and make sure of the pin-out before you plug it in.
The turn/dimmer/cruise/wiper stalk connectors may need to be re-pinned or pinned into a new connector. I posted the 88-93 GM T400 CK wiring diagrams so dig into em and see.
2) The 1994 T400 still uses the Harrison R-4 Radial compressor. You can mate this with your squarebody condenser and evaporator setup. I'd keep the hoses etc from the T400 chassis, on the engine bay side of the firewall, including the condenser. I used the Stock Sanden HT6 from a 1998 Diesel in my 1976. I had to make some custom hoses and added the wiring for the HPCO switch inline between the LPCO and the compressor clutch so I could run R134a if I decided to use R134a.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
