Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-19-2017, 10:16 PM   #1
superdav
Question about rear view temp/compass mirror from donor Yukon
I'm stripping a yukon I bought for my swap and thought the mirror would be cool to have too. I know there's a temp sensor but what about the compass? Is that built in?
superdav is offline   Reply With Quote
Old 04-19-2017, 10:56 PM   #2
El Dorado Jim
Re: Question about rear view temp/compass mirror from donor Yukon
ANDY4639 a member here has installed them in his trucks...pm him and find out...or ask this question in the 67-72 message board
El Dorado Jim is offline   Reply With Quote
Old 04-19-2017, 11:22 PM   #3
Greenlee
Greenlee's Avatar
I put one of these in my truck. There was no external sensor for the compass. Just the temp sensor and power wires.
Greenlee is offline   Reply With Quote
Old 04-20-2017, 05:55 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Question about rear view temp/compass mirror from donor Yukon
The compass is the cube behind the mirror. The senor is out on the front grille. Hot wire ground and the 2 senor wires is all you need.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-20-2017, 11:00 AM   #5
Reggler
What year is your yukon? Cause I've been wanting to do this since i got the truck, but most that I see in the junk yards have Onstar as well
Reggler is offline   Reply With Quote
Old 04-20-2017, 07:50 PM   #6
Andy4639
Old member
Andy4639's Avatar
Late 90's like 98 and 99 Tahoe have just the temp & compass!
Old 04-20-2017, 08:09 PM   #7
Reggler
I must have seen any tahoes at the u pull it yard then. Thanks
Old 05-03-2017, 12:17 PM   #8
Reggler
Just installed this mirror from an 02 Silverado, no airbag lights, no map lights. Wiring was simple. 5 wires, pink(red) is 12v+ ign, black is ground, light green is suppose to go to reverse lights so it doesn't dim in reverse, but ground it if you don't want that, then black with white goes to temp sensor and dark green goes to temp sensor.
Old 05-04-2017, 10:31 PM   #9
superdav
Thanks for the info and the Yukon is an 03
Old 05-07-2017, 01:36 AM   #10
El Dorado Jim
just picked up a mirror from a 99 tahoe, I got the temp sensor from the grill, it has two wires, a green and a brown..the mirror wiring has 7 wires...do you know how to wire this?
Old 05-07-2017, 08:24 AM   #11
Greenlee
Greenlee's Avatar
I forgot about the wire that goes to the reverse lights. Mine had that also.
Old 05-09-2017, 08:43 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Question about rear view temp/compass mirror from donor Yukon
Here are the diagrams I have for the mirror.
Depending on what the mirror came out of will be the colors you use.
