07-29-2018, 08:43 AM | #1 |
Which manifolds should I use for 5,3Ls install
Have a friend installing a 5.3Ls in a 72 suburban , any tips on which exhaust manifolds he should use
07-29-2018, 09:02 AM | #2 |
Re: Which manifolds should I use for 5,3Ls install
Motor mounts make a difference on what headers or manifolds fit well. A lot of guys like the TRAILBLAZER SS manifolds. Try over in the LS swap section.
http://67-72chevytrucks.com/aboard/f...play.php?f=206 |
07-29-2018, 12:49 PM | #3 | |
The Older Generation
https://www.ebay.com/itm/Hooker-Head...sid=m570.l1313 Worked like a champ. I think you can get them plain, painted, or ceramic coated...... LockDoc
07-29-2018, 03:08 PM | #4 |
I went with speed engineering motor mounts and headers.
07-30-2018, 12:28 PM | #5 |
Pontiac g8 gt worked great.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
07-30-2018, 03:10 PM | #6 |
I used a set from a 2010 Camaro. Fit great and looks stock.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
07-31-2018, 11:18 PM | #7 | |
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
08-01-2018, 06:34 PM | #8 |
I assume you're installing an automatic. On the off-chance you're using an external hydraulic slave on a manual(maybe a mechanical clutch as well), you'll need a 98-02 f-body manifold on the driver's side. That's per my research. I don't have it fully assembled yet myself.
08-01-2018, 09:30 PM | #9 |
Sanderson CSLS1
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
