Old 09-17-2018, 05:51 PM   #1
Dwyert4
Question on vin and spid
I figured out most of vin I think. 70 3/4 heavy long bed stepper. Has a 10 bolt rear end? Also 8 lugs axles. Is this considered a c20? Also what rear end is this and last but not least will the front clip fit a c10? Vin and spid pic included..
Dwyert4 is offline   Reply With Quote
Old 09-17-2018, 08:47 PM   #2
Mike C
Mike C's Avatar
Re: Question on vin and spid
The sheetmetal will work fine on a C10. Sounds like you have the Eaton HO52 rear axle in that truck. Not a whole lot of options,eh?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-17-2018, 10:24 PM   #3
jocko
jocko's Avatar
Yes, a 70 V8 C20 - and the sheetmetal is interchangeable. Note that, per the model #, I believe your truck was born a LB fleetside - appears the long step bed has been added at some point. Here's a flip for ya.
Old 09-18-2018, 05:49 AM   #4
Dwyert4
Thanks for the help. I'm trying to see if I can pick it up for a parts truck and part out the rest but the guy thinks he has a rusted gold mine. The stuff I need is in driver shape but the cab and bed leave a lot to be desired. Didn't even realize it should be a fleetside.
