05-08-2020, 11:55 AM | #1 |
Does LS ECM controller have AC input pin?
Finishing up the wiring on my LS conversion with the help of my brother (my wiring pro). We are about to connect the fans, AC, etc. into the underhood fuse box provided with the Connect and Cruise LS engine kit. He posed the following questions and I thought someone on this forum might know.
Thanks, Phil Does the Gen III engine controller have an AC input pin? If yes, will the engine controller turn on the engine cooling fans when the AC is turned on? |
05-08-2020, 08:35 PM | #2 |
Re: Does LS ECM controller have AC input pin?
You may want to post this in the ls swap section. Maybe an admin can move it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-08-2020, 09:54 PM | #3 |
There is some information you may be looking for in this post http://67-72chevytrucks.com/vboard/s...d.php?t=776599
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-08-2020, 10:08 PM | #4 |
I just posted this but it didn't show up. Hopefully this wont be a dup.
When I hooked up my 'connect and cruise' I ran the wire from the harness marked fan to the fan motor and the other side of the motor to ground. When the ECM wants the fan to run, it triggers a relay in the fuse box to put out a fused 12v+ -- not a ground like most stuff. I then used the signal to the AC clutch to trigger a separate relay to sent 12v+ to the fan. If the AC is running the fan will turn on. If the ECM wants fan it will turn on. If they both want fan, it still comes on with no chance of a back circuit. Hope this helps. |
05-08-2020, 10:28 PM | #5 |
Thanks gents for all the leads. It gets me heading in the right direction.
Phil |
05-09-2020, 10:02 PM | #6 |
Old member
The ECU should have a pin for the fans and as stated above it's 12 volts + not the ground.
I hooked mine up like this.
05-12-2020, 04:35 AM | #7 | |
06-10-2020, 11:33 PM | #8 |
On a aftermarket setup the fans are on by temp only with no speed input
Of ecu signal i am not sure if it would take speed into account In both cases you will need to run power to the fans through relays anyway If i where out 4x4 in slippery conditions i would want fans on by temp only |
