Old 04-25-2018, 03:57 PM   #1
54blackhornet
54blackhornet's Avatar
NAPA Ignition Switch Fail !
I bought a replacement ignition switch assembly from NAPA for my 71 GMC. First one would not slide into the spacer used to secure it into the dash, Basel also would not screw onto the threaded end of the housing. Returned it and tried another one only to have same issue. Box stated made in Tiawan...just a heads up !
71 GMC 1500
71 C-20
67 MGB G/T
07 Magnum RT “Did I mention it’s got a Hemi” !
54blackhornet is offline   Reply With Quote
Old 04-25-2018, 04:15 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: NAPA Ignition Switch Fail !
okay.
1969 307, t350
1950 Chevy Wagon
Old 04-25-2018, 06:31 PM   #3
cleszkie
cleszkie's Avatar
I swapped out my OEM ignition switch years ago with a repop unit. The repop sucked and ended up having issues. I ended up finding a used OEM unit to stick back in there. Its been working great for over a decade now. Something to be said for the OEM stuff, even if it is used. This goes for the reverse switch on the steering column too.
cleszkie is offline   Reply With Quote
Old 04-25-2018, 08:17 PM   #4
Fbks_Cruiser
Junior Member
Fbks_Cruiser's Avatar
I had a similar experience just last month. Bought a new ignition switch from Rock Auto. ACDelco brand. I had to file a bit from the switch body to get it to fit into the spacer. Seemed like the 3 tangs were off just a little. The bezel did screw on however. I am beginning to lose confidence in ACDelco quality.
1972 GMC K2500
Matt
Fbks_Cruiser is online now   Reply With Quote
Old 04-25-2018, 08:36 PM   #5
Boog
primer is finer
Boog's Avatar
I recently bought a window switch from rock auto for a cadillac. It said AC Delco but it also said made in Taiwan. It didn't fit....
That is the 2nd AC Delco switch I've had a problem with in the last couple of years.
Boog
69 Chevy stepside, 358/T350, 4.10 posi, 4.5/4 drop, rallys, poboy driver
09 Yukon SLT 4wd, 06 GMC crewcab Z71 5.3, 4.10
All GM..'nuff said,
Member of Jr Nation 88
Old 04-26-2018, 12:03 AM   #6
57taskforce
57taskforce's Avatar
Most ac Delco branded stuff any more is just re packaged aftermarket junk. There’s plenty of reading here and on other sites about this very topic. It’s Pretty disappointing.
'57 3100 350/700r4 35x12.5's
'72 K/20 Cheyenne 350/SM465 in pieces awaiting ly6 6.0 swap. http://67-72chevytrucks.com/vboard/s...d.php?t=662879
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6"RCD 315/75/16's
'01 Suburban LT K2500 Vortec 496/4l85E 240,000 and counting- drive train still all original.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
