Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-25-2019, 09:49 AM   #1
67bullet
back of cab sealer
what would be the best coating to put over the back of the cab I have it primed now,I will be installing the bed before I get it painted,Because I have to save money for paint and it may be a year or two before I achieve that.Thanks Jeff
67bullet is offline   Reply With Quote
Old 04-25-2019, 09:51 AM   #2
mongocanfly
Re: back of cab sealer
How did you do the back of the cab...did you just scuff and prime over the original paint?
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 04-25-2019, 10:07 AM   #3
67bullet
Yes it had the original paint I sanded with 80 grit and then 180 then 320 and then primed
Old 04-25-2019, 10:16 AM   #4
MP&C
MP&C's Avatar
What primer did you use?
Robert
MP&C is offline   Reply With Quote
Old 04-25-2019, 10:19 AM   #5
67bullet
Rust-Oleum filler primer
Old 04-25-2019, 10:59 AM   #6
mongocanfly
I dont know about Rust-Oleum filler primer....but if your original paint was only scuffed it should be fine...if you had sanded to bare metal youd need epoxy primer on it...
Mongo...aka Greg
Old 04-25-2019, 03:31 PM   #7
67bullet
what would I need just to seal it from the elements
Old 04-25-2019, 06:57 PM   #8
nsb29
nsb29's Avatar
I would get it off and then use an epoxy
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 04-26-2019, 06:10 AM   #9
MP&C
MP&C's Avatar
A filler primer is too porous and will not seal out the elements. You need about three coats of epoxy primer.
Robert
Old 04-26-2019, 07:49 AM   #10
nsb29
nsb29's Avatar
If what you used is what I think it is those rattle can primers are fine for home projects not your truck you can probably wash it off with a little lacquer thinner donít take a chance
Old 04-26-2019, 08:38 AM   #11
MP&C
MP&C's Avatar
If what you used is what I think it is those rattle can primers are fine for home projects not your truck you can probably wash it off with a little lacquer thinner don’t take a chance
Good observation. It never hit me we were dealing with spray bombs here....
The primer used does not seal, and anything sprayed on top of it will likely cause lifting (adhesion) issues as any solvents will soften or wrinkle the primer. If you don't have the option of spray equipment, find a good epoxy primer and use a low knap roller, or brush, etc. to provide the application coverage needed. At the end of the day it will get blocked out before you topcoat with anything, and in the meantime it has the ability to seal out moisture.
Robert
Old 04-27-2019, 05:40 PM   #12
Foot Stomper
Foot Stomper's Avatar
The best thing you could do for it without starting all over this time is to paint it. Get a gallon of Rustoleum and paint it.
When you are ready and financed to paint it correctly, you'll need to start over back to original paint and or bare steel.
Rattle can products are not a good idea for proper finish and corrosion resistance.
If you don't paint it, you will have a rusty project in no time!
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 04-28-2019, 09:44 AM   #13
67bullet
Ok guys thanks for all the replies
Old 05-02-2019, 12:17 AM   #14
halfstep
I really know next to nothing about paint & body work, but the most common two words I hear from the experts are "Epoxy Primer"...so if you are just talking back of cab and other random spots you may consider getting a couple cans of true 2k epoxy primer in a spray can. $15-20 and it has a nice adjustable spray pattern valve. Search on line.
halfstep is offline   Reply With Quote
Old 05-02-2019, 07:54 PM   #15
67bullet
Hey guys I sanded down to metal and applied 2k epoxy primer to the back after replacing the cab corners and thanks for all the replies and advice
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
