Old 01-31-2018, 10:55 AM   #1
Sgtfluffy16
12 bolt backing plate
Can you guys help me? I have been searching for a few days now trying to get a parts vendor for a new passenger side rear backing plate for a 12 bolt gm truck rear axle. I can't seem to be able to purchase one anywhere. Any help?
Sgtfluffy16 is offline   Reply With Quote
Old 01-31-2018, 11:05 PM   #2
stanski
Re: 12 bolt backing plate
Drum brakes I assume?
stanski is offline   Reply With Quote
Old 01-31-2018, 11:07 PM   #3
Sgtfluffy16
yes sir, drum brakes
Old 02-01-2018, 09:50 AM   #4
sweetk30
sweetk30's Avatar
should be the same as 10 bolt other than shoe size and width . also parking brake cable style .
i know guys swap them a lot from 1 axle to other .
my 2wd i did . the 12 bolt rear has the wide brake backing plate's on it for 1/2 ton .
whats wrong with yours ?
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-01-2018, 10:04 AM   #5
Sgtfluffy16
it rusted through. I just need a new replacement one. The axle is out of i think a 1980 K10 but its going to a custom build (51 chevy 3100)
Old 02-01-2018, 09:28 PM   #6
Sgtfluffy16
anyone???
Old 02-01-2018, 10:13 PM   #7
geezer#99
geezer#99's Avatar
You could try here.
They might have one or know a source.
https://www.currieenterprises.com/Ba...0Brake%20Parts
Or here.
https://www.dormanproducts.com/gsear...or+drum+brakes
Old 02-01-2018, 11:05 PM   #8
Sgtfluffy16
I already contacted dorman, No luck on my search and no response from them. The curries, are ford loaded brake assemblies
Old 02-01-2018, 11:10 PM   #9
geezer#99
geezer#99's Avatar
Oops!!
Have you tried your local parts emporiums?
Old 02-01-2018, 11:13 PM   #10
Sgtfluffy16
I am my own local parts emporium.. hahaha
Old 02-11-2018, 07:35 PM   #11
Pontiac1976
Pontiac1976's Avatar
If they just rusted wore out on the wear points. (slide area) sand blast them weld them back up. Old Truck fix backers. I bleave that no one makes them yet.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-11-2018, 08:20 PM   #12
Sgtfluffy16
no they rusted out and got holes in them, need replacment ones.
Which BTW big shoutout to @1957Chief for sending me a pair of backing plates. The are a good fit. They will get a quick sanding, primer, and paint before installing. THANKS!
