02-15-2018, 09:41 PM | #1 |
Upholstery Ideas After Removing Gas Tank Behind Seats
I am looking for ideas to upholster the area behind the seats after the gas tank has been removed. I can work out the flat areas using 1/16" Luan paneling, but I'm not sure how to round out the cab corners for a nice clean look.
Thanks, POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
02-15-2018, 09:50 PM | #2 |
Re: Upholstery Ideas After Removing Gas Tank Behind Seats
1/2 " wire mesh plastic coated....
Stan 67 swb BLU MULE posted via flip-fone |
02-15-2018, 10:42 PM | #3 |
I replaced mine with a custom sub box the size of the tank, using the same mounting bolts and a shallow mount sub. I then used MDF and cut it to the shape of the curved corners, and incorporated storage openings for the jack and a fire extinguisher. You can then cover it with material, or carpet, or felt, or whatever... Will try to post a pix.
