08-16-2018, 10:58 PM | #1 |
AC blower motor wheel project
I have been thinking about doing this for awhile. I wanted to see if could get the AC to blow hard like a late model. After some research I found a late model blower wheel that was the right size. I had to buy blower motor with the wheel just to get the wheel. I got it on ebay for $33.00 it is for a 07-11 jeep liberty. The wheel has 41 fins on it and my 72 AC wheel has 29 fins. The fins on the newer one are also much larger. This took me a few hours to put together. The new wheel would require a much longer shaft that my motor has so I cut the center out and I clipped and cleaned up an old chevy blower wheel and epoxied and rivet them together. The fit was so good they self centered themselves. I had to open up the blower housing hole about a 32d all the way around to get the wheel in. Also took some side cutters and clipped the top of the fins at an angle for clearance. This runs smooth and quiet and blows hard. I think on medium it blows about what it used to on high.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
08-16-2018, 11:26 PM | #2 |
Re: AC blower motor wheel project
Now that is a good project. Thanks for that info and pictures.
08-17-2018, 12:03 PM | #3 |
Classic Chevy Truck Inventions.
You should be given the Ingenuity Award for the year. Bill P.S. what is the difference in the heater only wheel, this may help us non-AC guys too.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-17-2018, 12:28 PM | #4 |
Thanks! I'm sure that will be one of my future mods.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-17-2018, 08:38 PM | #5 |
Bill, I do not know about the heater only wheel. I am sure someone here does.
08-19-2018, 06:22 PM | #6 |
A short video trying to show how it blows out the center vent. https://youtu.be/hcRlWh4QmM8
08-19-2018, 07:40 PM | #7 |
It's saying the video is unavailable when I try. However your mod is on my list of things to do.
08-19-2018, 08:15 PM | #8 |
Ok I will try to work on the video. Thanks
08-19-2018, 08:38 PM | #9 |
20' Daredevil (Ret)
It's not just a Red71gmc problem....I couldn't see the video either. Looks like a very good mod, thanks for posting!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-19-2018, 09:24 PM | #10 |
I looked through your driver build rsgt. Your a resourceful guy. My truck originally was the same colors and I wish the PO would have repainted it those colors. It just looks good on these trucks. Especially with the rally rims. Good job.
08-19-2018, 09:29 PM | #11 |
Your video worked this time. I will be doing this. It looks like it could be used for a hair dryer if I just still had hair.
08-20-2018, 06:12 AM | #12 |
Old member
That looks like it's pretty strong. I wonder if it would work on a 64 SS Impala as well.
rsgt, Here is your link.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-20-2018, 08:54 AM | #13 | |
08-20-2018, 09:00 AM | #14 |
Here are a couple more pictures. I put a heavy weight on the wheel when I glued them together, Then when it was cured I put the rivets in. I put a weather strip seal around the edge of the motor plate before I put it back on the truck.
08-20-2018, 09:36 AM | #15 | |
08-20-2018, 10:51 AM | #16 |
Old member
Thanks, the truck does pretty good as is but my 64 SS on high is like slow speed in my 71 C 10.
10-26-2022, 03:04 PM | #17 |
Tagging so I can find it later. Nice mod!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
10-26-2022, 09:59 PM | #18 |
I did your mod on mine when it put it together a year and a half ago. It works great.
10-27-2022, 06:28 AM | #19 |
Where do you guys find the time to do this? On my list now twice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-27-2022, 12:30 PM | #20 |
Can't speak for trucks but the hot tip for C3 (68-82) Corvette blower motors was to use C4 (84-96) Corvette blower motors and add a 3/4" spacer. Not sure if they had more blades but they were at a different pitch and the cage was longer. It supposedly worked well although I never did one.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-28-2022, 10:13 AM | #21 |
Also, posting just so I can find it later.
