Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-11-2018, 04:47 PM   #1
Southcity
Southcity's Avatar
66 Suburban - Some license light love
Decided to give the license plate light some attention. The only new parts used was a new LED light and light-socket pigtail assembly. I already had everything else (wiring connectors, primer, paint, gasket material).
1. BEFORE: The worse-for-wear original parts of the dis-assembled license light
2. AFTER: Cleaned, primed and painted parts with a new cork gasket
3. BEFORE: Another view of the worse-for-wear original parts
4. AFTER: Ready for re-assembly
5. Ready for installation with new weather pack connector
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 10-11-2018, 08:14 PM   #2
MusicMan70
MusicMan70's Avatar
Re: 66 Suburban - Some license light love
Very Nice; Standing by for the light show!
MusicMan70
1961 GMC Suburban
MusicMan70 is online now   Reply With Quote
Old 10-18-2018, 02:36 PM   #3
Southcity
Southcity's Avatar
Night shot
Old 10-18-2018, 03:09 PM   #4
MusicMan70
MusicMan70's Avatar
There it is; Very bright and readable! Thanks for the follow-up.
MusicMan70
1961 GMC Suburban
Old 10-24-2018, 12:49 PM   #5
gbustillos
This is my next project on 66 Burb 4x4. I'm not sure what i need because i have not removed anything yet. Good job though lots of light given off. So the LED works perfectly fine. I was wondering if I should only use LEDs for all my lights.
gbustillos is offline   Reply With Quote
Old 10-24-2018, 01:12 PM   #6
Southcity
Southcity's Avatar
If improved lighting is the goal it's hard to beat LED. Long life, less load on the system, less heat generated and of course improved lighting. There are a few things to consider if going to all LED, for example the dimmer switch for dash lights will not work without using something like the below:
https://www.thoroughbreddiesel.com/9...SABEgIz2PD_BwE
If LED's are used for the turn indicators you will need an LED specific flasher. There is a lot of info about all this on this board.
