Old 01-17-2021, 01:47 PM   #1
67 K10
Water leak
Hey guys, I have been battling a water leak under my dash on my 67 k10. Had the windshield out new gasket and glass , had it in the glass shop twice. I can't find where it is getting in. Just wondering if anyone has had the same problem and has any suggestions. Thanks!
67 K10 is offline   Reply With Quote
Old 01-17-2021, 02:27 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
Re: Water leak
Check along the body seam inside the cowl, or it could even start in your drip rail above the windshield, then channel down the A-pillar.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 01-17-2021, 02:31 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Water leak
Per the GM shop manual you should put sealer at each top corner and extend it out at least 6" so it gets that seem in the top. May not fix it but it's a start. The dash if you look has holes in the area around the bottom of the glass. Water comes in at the top and comes down the windshield sides then out at the curve at the bottom and drips through the holes in the dash.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-17-2021, 03:44 PM   #4
cj847
cj847's Avatar
Re: Water leak
is it leaking only on one side?
Are you sure there is no anti freeze in it (heater core leak)?
There is a seam under the cowl about 10" from the edge of the truck on both sides. They do rust there a lot esp if it was ever clogged up.
cj847 is offline   Reply With Quote
Old 01-18-2021, 03:22 PM   #5
SIXTY9
Re: Water leak
Check the wiper motor seal. I chased a leak and found mine bad.
SIXTY9 is offline   Reply With Quote
Old 01-18-2021, 06:49 PM   #6
HO455
HO455's Avatar
Re: Water leak
Can you be more specific as to where? There's at least 5 feet of under dash!
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 01-18-2021, 09:40 PM   #7
Grumpy old man
Grumpy old man's Avatar
Re: Water leak
Use CRL 1716 flow grade sealant to cure water leaks from the gasket /windshield
https://www.crlaurence.com/crlapps/s...ModelID=19965#
with the gun dispenser CRL 181AG
https://www.crlaurence.com/crlapps/s...&ModelID=19352
