Old 05-15-2018, 11:40 AM   #1
71C10longbed402
1971 C10 Steering
My newly acquired 71 has loose steering. It wonders around a lot especially on rough roads and changing lanes. how do I know if it is the steering box or linkage?
71C10longbed402 is offline   Reply With Quote
Old 05-15-2018, 07:51 PM   #2
88gtstreetrod
Re: 1971 C10 Steering
I am still learning about these.. I just ordered a new one fro mine (leaking). Interested to see what everyone says. My guess it's the box.
88gtstreetrod is offline   Reply With Quote
Old 05-15-2018, 08:05 PM   #3
SeanB242
SeanB242's Avatar
Have someone turn the wheel while you check for loose tie rods and play in the steering box.
SeanB242 is offline   Reply With Quote
Old 05-15-2018, 09:14 PM   #4
jessemthompson
I would lift the front end and inspect all your steering components. My truck had loose steering when I first picked it up and I attributed it to not being rack and pinion. I hadn’t driven one for about 20 years. When I did some suspension upgrades, I discovered my pitman arm was loose. The nut was only finger tight. It could’ve ended badly for me.
jessemthompson is offline   Reply With Quote
Old 05-15-2018, 09:19 PM   #5
zicc1835
zicc1835's Avatar
you can also jack up the front end and try to move your tires back & forth while someone looks at the tie rods, center link, idler arm ,and pitman arm for play...let us know what you find
zicc1835 is offline   Reply With Quote
Old 05-15-2018, 09:31 PM   #6
Robznob11
Robznob11's Avatar
Well sir I have been battling this as well. I have every part new even new redhead gear box and it still has more play than I like. Toe out can cause it. I'm actually wondering if the column it self could have play in it? I dont have a rag joint anymore so I know it is not that!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-15-2018, 11:55 PM   #7
rjs53
The wider front tire will grab the ruts and cause it to pull. If it has a manual box, you can loosen the nut and turn the screw in a full turn or so.
2003 Dodge 2500
1969 C10
2014 Camaro SS 1LE
rjs53 is online now   Reply With Quote
Old 05-16-2018, 09:20 AM   #8
Faastone27
Faastone27's Avatar
OP.... Looks like your lowered? . Are you on drop springs in front? do you feel like it may also be bump steer contributing to the "loose" feel? Mine was like that until i did drop spindles now it is perfect.
Faastone27 is offline   Reply With Quote
Old 05-17-2018, 10:59 AM   #9
71C10longbed402
Thanks!
Old 05-17-2018, 11:00 AM   #10
71C10longbed402
Yes drop springs Thanks!
Copyright ©2000 - 2018, vBulletin Solutions Inc.
