02-13-2013, 01:49 AM | #1 |
The Possum build
Well let's see..... searched for about 6 months and finally found a good rust free body and ran like a top. 1972 CST original ochre now red. It ran when I bought it but the steering was SCARY!!!!! So I decided to trailer it back home to Memphis.
Got it home and it would not start, timing had jumped out. Started the strip down. Seems like the previous owner had an aversion to screws, he would take 8 out and put 3 back in, bonus, makes it a lot easier to take it apart. As far as rust...... found a spot about the size of a baseball at the bottom of each kick panel. I can hear the angels singing NONE anywhere else. Plans for the Build New Motor 420 HP 490ft/lbs 350 SBC 700r4 trans rebuild front Performance Suspension kit disc brake rear? 373 gear 33x12.50 tires 4 inch suspension lift shave tailgate shave rear hatch vintage air a/c |
02-13-2013, 01:57 AM | #2 |
Re: The Possum build
front clip off, loaded to go to shop.
new engine frame out!!!! |
02-13-2013, 11:19 AM | #3 |
Looks like you got a great start!
Good to have you on this board...lots of good info & folks here!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
02-13-2013, 04:30 PM | #4 |
Nice! Lot's of pic's please! Welcome to the board!
02-13-2013, 06:53 PM | #5 |
Welcome from Utah
02-26-2013, 10:07 AM | #6 |
Good Lookin truck!! Welcome From a fellow memphian!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
02-26-2013, 04:18 PM | #7 |
Performance Suspension kit didn't work out, their ball joints were standard grade and the parts were mixed manufacturers McQuay-Norris and MOOG. so now on the search for quality front end parts. Prefer MADE IN AMERICA.
Rock auto has MOOG, raybestos, and other random manufacturers. I have also heard good things about the NAPA parts. They have two levels of parts Master ride Chassis series which are the low end and then the NAPA Chassis which look like grade 8 and blue poly bushing and have a lifetime parts warranty (with a lot of exceptions). they say made in America. "The NAPA Chassis warranty does not cover any loss due to misuse, alteration, accident, abuse, neglect, normal wear, improper application or installation of the products. This warranty only applies to NAPA Chassis products installed on passenger cars, vans, and light trucks. It does not apply to products installed on vehicles or equipment used for the following: towing, racing, public service, security, government, off-highway recreational, offhighway competition, fleet or commercial purposes, or if used in any aircraft or aviation application. The warranty does not cover any loss or liability for incidental or consequential damages that may be caused by a breach of this written warranty." |
02-26-2013, 05:28 PM | #8 |
Further research the NAPA top grade parts are made by raybestos and are the same as Raybestos pro grade products.
Upper ball joint NAPA 46.46 same Upper ball joint rock auto 29.99 |
03-04-2013, 04:53 PM | #9 |
I'm looking for bolt and screw kits specifically for a blazer. Does anyone make them and who carries them? I looked at the kits at The Fillling Station and talked to one of their techs and he didn't think their were any Blazer kits.
I suppose you could use use a fleetside kit to cover most of the outside but still need all the top parts.
I'm not saying let's go and kill all the stupid people. I'm just saying let's take off all the warning labels and let the problem sort itself out. |
