05-06-2017, 09:11 PM | #1 |
no battery.test wires with battery charger ?
Can I check hot wires on a 78 chev truck with a battery charger hooked up to the battery cables. Trying to clean up some wires but don,t want to keep taking the battery out of other truck all the time.
05-07-2017, 07:02 AM | #2 |
Re: no battery.test wires with battery charger ?
Sounds like a fire about to happen. Test with tester! Unless you would like to see your hard work melting.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-07-2017, 08:04 AM | #3 |
Depends on the charger. If it is something like a 6 amp unit, should be fine. Just keep in mind that most battery chargers don't have very good voltage filters and at low current draw, may over volt the system a bit. Lead acid batteries are a lot better at handling voltage spikes then vehicle electronics.
Plus some of the "smart" chargers may not provide voltage if they don't see a voltage already on the circuit. |
