Old 07-21-2014, 08:55 PM   #1
Drewkimble48
5/7 drop ext cab setup
sometime in the future, hopefully soon, I will be dropping my truck. what I have come up with is that i will be dropping the front 5" and the rear around 6" or 7". I want my truck to ride really well since it will be my daily driver. I have seen a lot of you guys suggest the DOETSCH TECH shocks and will be getting some for the front for sure. my question though is what kind of shocks would you put on the rear, air shocks or some doetsch tech shocks?
has any of you guys used air shocks on your lowered obs trucks?
what do you guys think of monotube shocks? are there any for our lowered trucks?
thanks guys and have a great week!
Drewkimble48 is offline   Reply With Quote
Old 07-21-2014, 09:09 PM   #2
k5hart
k5hart's Avatar
Re: 5/7 drop ext cab setup
I'm a big fan of the Belltech Street Performance shocks. I have them on my '06 and it rides great. Granted it's not as low a your going. On my '91, it was 4/6 and I was using the Doestch shocks with air lift helper bags and about 15lbs. air. It also rode well.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 07-21-2014, 09:11 PM   #3
Drewkimble48
By air lift helper bags, are you talking about the ones that are used for towing?
Old 07-21-2014, 09:22 PM   #4
k5hart
k5hart's Avatar
Yes. They mount between the frame and leaf pack. I've had them on both trucks and are pretty useful. I use the heck out of them on my current truck.
Old 07-21-2014, 09:27 PM   #5
Drewkimble48
Along with the air bags though, you were using Doestch shocks in the rear right?
Old 07-21-2014, 09:39 PM   #6
k5hart
k5hart's Avatar
Correct.
Old 07-22-2014, 07:51 AM   #7
Kudzupatch
Kudzupatch's Avatar
I'm a big fan of the Belltech Street Performance shocks. I have them on my '06 and it rides great. Granted it's not as low a your going. .....
Same here. 4/6 drop with helper bags and 10-15 lbs and rides at least as good as it did new.
Kudzupatch is offline   Reply With Quote
Old 07-22-2014, 08:51 AM   #8
LEEVON
LEEVON's Avatar
I'm kind of old school I guess but I have never been happy with "drop shocks". They are nothing special, just re-branded over priced stock applications, although I hear the Belltech SP's are a step-up. I always refer to the Monroe chart and find a light truck shock with the right mounts, length and travel by measuring the distance AFTER the drop.
Monroe Sensa-Trac
37027 - rear (92 Cherokee Sport)
37137 - front (98 Dakota)
Even more important though is using shock extenders in the rear which re-align the lower shock mount. You will gain 2-3" of travel and get closer to the stock angle. If you want to take it a step further you can relocate the upper frame mount. No drop shock will make up for a 50 or 60 degree angle...shocks aren't effective that way.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-22-2014, 07:08 PM   #9
Drewkimble48
I looked at the belltech shocks and saw they were for a 4/6 drop, you guys think they might work for a 5/7 drop as well?
I looked at the helper bags and came up with some for $325 for them. Is that the cheapest for them or am I looking at the wrong ones?
here's the website to the helper bags I found
http://www.ebay.com/itm/Air-Lift-571...04c53e&vxp=mtr
Old 07-22-2014, 07:16 PM   #10
1badgmc
1badgmc's Avatar
Yes. They'll work.
Helpers won't be cheap for a quality setup. They're not a requirement. If it's too much on the budget right now, don't worry. Get your drop and then do the helpers later.
Old 07-22-2014, 07:31 PM   #11
Drewkimble48
Well I believe I know what will be a great setup for my truck now. Thanks guys for your help and recommendations. When I can find a place to work on my truck and have more funds, I'll start posting pictures of the truck doing the body work and everything else.
hopefully my 315k engine will still keep going or I will be having to hold on all the suspension and body work stuff.
Also, if you guys need any help or suggestions doing body work, feel free to ask me. It's at least one thing that I can contribute to this forum and help you guys out. I always want to return the favor.
You can take a look at 2 of my personal hot rods and see the quality of body work I do:
http://67-72chevytrucks.com/vboard/s...09151&page=303
the orange short wide and chevelle
Once again thanks guys and have a great week!
Old 07-23-2014, 01:05 PM   #12
likaroc13
Rollin' Old Skool
Another vote for Belltech Street Performance shocks. I first installed a set on my old '93 S-10 with 4/5 drop, & I was pleased with their perfomance. So when replacing shocks on my '97 Tahoe with 4/6 drop, I went with the same shocks.
I had the Doetsch Tech on my old '93 C-1500. They rode great up front. I think they were a bit soft for the 8" rear drop I had though.
I got my first set of Belltech shocks through Tony (aka NORCAL SS). He's a member here, as well as Fullsizechevy.com & GMfullsize.com. I got the set for my Tahoe through The Suspension Source. Just a couple places you might check with for prices.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-23-2014, 05:51 PM   #13
Drewkimble48
To be able to get possibly better prices, do I need to sign up for a membership? if so then I will go ahead and do so. Besides, I spend a lot of time at work on this website and it's always helpful!
Old 07-23-2014, 07:37 PM   #14
Tom
driving is in my blood
Tom's Avatar
doetsch tech up front and shock extender brackets with stock shocks in the rear. Helper bags as well if you plan on ever actually putting things in the bed and not bottem out.
Old 07-24-2014, 12:12 AM   #15
likaroc13
Rollin' Old Skool
Nope. You can just shoot Tony a PM or his email is norcalss06@aol.com. You can find The Suspension Source via the GMfullsize forum or their website, but you might get a better deal from the forum.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 07-24-2014, 06:45 PM   #16
Drewkimble48
it may be a bit before I'm ready for shocks. I'm going to buy some 18" wheels before I start buying suspension stuff. that ways I don't have any lower control arm issues when I drop the truck. I'll definitely shoot him an email when I'm ready to purchase.
Old 07-24-2014, 09:25 PM   #17
k5hart
k5hart's Avatar
I'll agree on the shock extenders. I had them on my '91. Forgot to mention them. Don't go cheap on the helper bags. It will save you headaches on installation.
Old 07-25-2014, 05:51 PM   #18
Drewkimble48
Isn't shock extenders for short wide pickup instead of extended cab trucks?
Old 07-25-2014, 06:33 PM   #19
Drewkimble48
something else that I didn't even think of until now but since I'm lowering the fron 5", have any of you lowered guys had to buy the alignment kit from belltech or elsewhere?
Old 07-25-2014, 11:13 PM   #20
likaroc13
Rollin' Old Skool
Can't speak for others, but I know my old '93 C-1500 never used anything like that, & it was lowered 5" up front. I had 2" spindles & 3" springs, both from Western Chassis. Once it was done, the shop doing the drop just took it to a local shop for the alignment.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 07-25-2014, 11:25 PM   #21
Drewkimble48
Well I was adding up how much everything was going to be and started looking at how much it was going to cost if I bough a complete Belltech kit. Through them it was going to cost $1247 for everything with shocks and extenders. I checked summit to see if it was cheaper and low and behold, the happened to have free shipping for the entire kit, whole lot cheaper than going direct through Belltech and it came with a $150 mail-in rebate if I bought it before july 31st. Either way, I could have pieced a kit together and spent the same or more for everything or just buy the kit with no hassle which is what I did tonight.
Old 07-26-2014, 12:03 AM   #22
likaroc13
Rollin' Old Skool
Yeah, when I bought mine back in the day, it was a kit as well. I think I got it from Sport Truck Direct. It came with the spindles/springs/flip kit/ C-notch & shocks. I believe it was under $800 shipped. I remember shopping around with everybody I could find listed in my Street Trucks or Truckin' magazines. Summit is no doubt hard to beat on some of their deals. I always check to see if they carry what I'm looking for before making final decisions on anything.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 07-26-2014, 01:32 PM   #23
Drewkimble48
Talking Re: 5/7 drop ext cab setup
I tell you this much, I would be up $*#t creek buying anything if it wasn't for Summit Racing, Jegs, or Competition Products.
Old 07-26-2014, 11:51 PM   #24
Tom
Tom's Avatar
No, it doesn't matter. The axle attaches to the truck the same in all 1/2tons. It just lowers the attachment point of the shock.
Old 08-15-2014, 08:32 PM   #25
Drewkimble48
You know I just thought of something. for you 5/7 drop guys, did you have to remove your inner wheelhouses?
