Old 10-09-2018, 04:30 PM   #1
72-k20-burb
6.0 LS swap header fitment issues
Hi folks,
long time reader, first post.
I bought a 72 k20 suburban a few months back, and have proceeded to tear out the old power plant and put in a low mile l96 (6.0). I got the old np205 on the back still and it's in the stock mounting location.
I'm using the dirty dingo 4x4 crossmember kit with clamshell mounts.
The stock manifolds on the 6.0 did not work, and I just bought THY-323Y-C doug thorleys and they wont work. Ah!
I checked throley and summit, both sites make it seem like they should fit. Is everyone using slider mounts to move the motor back? I'm hoping to avoid that so the trans and drive shafts all stay in stock locations.
Are there other headers I should get that will clear? I checked the thorley 324s and they have the same fitment listed online. At $650 a pop I don't want to cut these up to make them fit unless absolutely required.
Thanks!
72-k20-burb is offline   Reply With Quote
Old 10-09-2018, 08:26 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 6.0 LS swap header fitment issues
Welcome....
I got sucked into that "they should fit" thing...I wound up using headers for a hummer...but I would never recommend anyone do this...it took a ton of modifying to make it work...if I was doing it over I would probably use LS3 manifolds...I think those would work..and it being a K series will make it even more difficult to dodge driveshaft,axle and such
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-09-2018, 08:45 PM   #3
72-k20-burb
The LS3 exhaust manifolds look pretty darn close to the ones that came on the l96. Do they hug tighter than other manifolds?
Dirty dingo has 1302LS1-C Schoenfeld headers that supposedly work for 4x4, however they won't call me back after a few voicemails. I already spent enough money there I would have hoped for better service.
I read a few people here used Speed engineering, they have a note that says no 4x4..
Getting custom exhaust made seems simple enough to clear the 4x4 transfer case if I can first clear the frame... I'd really rather not cut or modify like you said.
Old 10-09-2018, 10:19 PM   #4
mongocanfly
I'm not sure what the L96 mani looks like...
Here's the diff between a 5.3 and a LS3 mani...the 5.3s stick out from the engine about 3/4" more than the LS3
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-09-2018, 10:25 PM   #5
CJM72
We should trade! I have a set of THY-324Y-C headers that fit inside the frame rails fine, but basically were rubbing on the firewall on the driver's side. If you have clearance in that area, these might work for you. Too bad we weren't closer, or I'd let you try to fit them. I could have just hammered a dent in the firewall, but I didn't want to do that. Almost bought the 323y's as I've seen others fit them just fine.
https://boston.craigslist.org/sob/pt...719481365.html
CJM72 is offline   Reply With Quote
Old 10-09-2018, 10:29 PM   #6
CJM72
For the record, I have the same Dirty Dingo crossmember with a 6.0 and a 4l65e adapted to the np205. Left the NP205 in the stock location, but I have a k5. It's too bad, these headers tuck up nicely, cleared the frame, spring shackles, and look great.
Old 10-09-2018, 10:42 PM   #7
mongocanfly
CJM.....So the LS3 manis fit ok?..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-09-2018, 10:48 PM   #8
72-k20-burb
Thanks for the comparison Greg, I'll upload a picture of the l96 ones for future reference.
Is the k5 front frame geometry any different from the c10/k20 etc?
What 6.0 do you have and what headers did you end up using? I've heard these 323s fit with the LQ9/4s so that's why I bought them hoping it would be the same for the l96 6.0.
The photo from your craigslist ad makes it look like your motor sits pretty similar to mine. I'm tempted to send mine back to summit now and get those 324s. I only went with the 323s over the 324s because of the 1-7/8 sizes primaries.
Old 10-09-2018, 10:51 PM   #9
mongocanfly
I've also got a set of manis off my LQ9 and they are the same as the ones from the 5.3
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-09-2018, 11:11 PM   #10
CJM72
Yup, fit great. I have them bolted in there now! Just would like to have headers.
Old 10-09-2018, 11:16 PM   #11
CJM72
Looking at the pictures in my thread, the cross member and motor location look identical. I believe the 4x4 trucks all have same frame geometry up front. You can see where mine driver's header was touching the firewall. Couldn't even slide a piece of paper in there!
Old 10-15-2018, 04:04 PM   #12
DWilbur
The DD engine mounts don't work with LS 4X4 swap. The issue is the mounts set the engine 1-1/2" lower that 2 wheel drive LS swap. In the end I modified my Dough Thorley Headers had to rework the front header tubes on both sides to clear the frame so they fit.
DWilbur is offline   Reply With Quote
Old 10-25-2018, 03:38 PM   #13
72-k20-burb
Interesting. Do you mean the sliding DD mounts?
I bought their 4x4 mount and crossmember kit, so far everything fits great. Except the headers..
I'm halfway through an exchange with summit so I'll post when I get the new ones and test fitment.
Old 10-25-2018, 04:26 PM   #14
Clyde65
Clyde65's Avatar
Just curious but maybe a shortie header would work. I have the Sanderson CSLS1 and although my truck is a 2wd and a 65, I would think they will fit. Just a thought.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-26-2018, 09:22 AM   #15
DWilbur
The shorties should work. I have a set of Headman shorties that I tried but they are about the same as stock exhaust manifolds. I did not like the way they dump strait down if they dumped at an angle they would work better for my truck.
Old 10-26-2018, 02:22 PM   #16
72-k20-burb
looking at the picture the no1 primary looks like it takes the same turn as the others I've tried. I went to a c10 gathering an a lot of people there had headers that all fit ok, but none of them were 4x4 LS swaps.
The stock manifolds on the l96 will only require a small modification to fit, but I'd really like to get some longer headers on there.
Right now I have a 6l90 on and the np205 sits in it's stock location so all drivetrain is the same. Would be nice to keep from moving anything. Finding the right exhaust seems simpler/cheaper than making new transmission mounts or new drive shafts.
Old 10-26-2018, 02:36 PM   #17
DWilbur
Here is picture of the Dough Thorley Headers I had to modify to fit. Both front tubes is the issue they hit the frame. now they clear by 3/8"
Old 10-26-2018, 09:45 PM   #18
72-k20-burb
Are those the 323s or 324s?
Old 11-03-2018, 09:59 PM   #19
Slippy
I used the Speed Engineering ls swap headers on my K5 Blazer 4x4. Worked great. Only issue is the spark plug wires on the drivers side will have to be changed to the msd flexible boot type.. they were around $169 shipped on eBay..nice thick flanges and look great.
Slippy is offline   Reply With Quote
Old 11-04-2018, 04:41 PM   #20
72-k20-burb
Those look good. I looked at speed engineering a bit, everything I found on their website says no 4x4.
What motor mounts / crossmember are you using?
Old 11-04-2018, 04:48 PM   #21
72-k20-burb
So I got the DT 323's exchanged for the 324s and they fit. mostly.
Passenger clears, drivers side had to shave a tiny bit.
Old 11-04-2018, 05:58 PM   #22
Slippy
I’m using the pacific fab crossmember and mounts.
Old 11-04-2018, 10:23 PM   #23
72-k20-burb
[QUOTE=Slippy;8377748]I’m using the pacific fab crossmember and mounts.
Your clearence makes me jealous. I was kind of stuck on using long tubes for some reason. I think the LS3 manifolds was a good back up option, good to know about speed engineering too.
Old 11-04-2018, 10:50 PM   #24
Slippy
[QUOTE=72-k20-burb;8377901]
Old 12-22-2018, 06:05 PM   #25
tim3834089
I have a set of 323y I’d like to trade for 324y.
They are new and never ran. Headers only
tim3834089 is offline   Reply With Quote
