Old 01-20-2019, 05:37 PM   #1
rsavage
rsavage's Avatar
Brake line junction block - 1969 4X4 K5 Blazer
Any one know where to source a brass junction block for a 4X4 that goes on the inside of the driver's side inside the frame? The front brake hose goes into it through the frame, and there are two brake lines that go in either side. There is a hollow 5/8 headed bolt that threads into the brake hose. Thanks for any help. Rick
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-20-2019, 10:08 PM   #2
simicrintz
Re: Brake line junction block - 1969 4X4 K5 Blazer
Are you looking for the proportioning valve?
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 01-20-2019, 11:04 PM   #3
rsavage
rsavage's Avatar
No, it is a junction block on the inside of the frame.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-20-2019, 11:26 PM   #4
simicrintz
Well now I am curious!!
-Bruce
1971 K5 Blazer 4WD
Old 01-20-2019, 11:32 PM   #5
rsavage
rsavage's Avatar
I'll try to remember to take a couple of photos tomorrow.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-21-2019, 12:18 AM   #6
Blazerowner
Blazerowner's Avatar
I think there is one on the left and right if I remember correctly. I believe inline tube or LMC would have them.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 01-21-2019, 08:15 AM   #7
rsavage
rsavage's Avatar
Didn't see the one I need on inline's site. Thanks though.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-21-2019, 08:49 AM   #8
jjzepplin
jjzepplin's Avatar
I have some stuff I took off my 70 4x4 4 wheel drum power brake system. Think it might be in that stuff?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-21-2019, 03:41 PM   #9
rsavage
rsavage's Avatar
This one is specific to the driver's side. I believe I may have got it to stop seeping. Took it apart again and replaced the copper washers again. Although the hollow bolt threads into the brake hose, the face of the hose end also abuts a washer (banjo fitting). I took a couple of photos. If you have one, hold onto it.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-21-2019, 04:46 PM   #10
Blazerowner
I ordered all new prebent lines for mine i have to check if it’s in the box with them.
Kirk
66 Nova
Old 01-21-2019, 05:12 PM   #11
simicrintz
Interesting; is is just a connection point or does it have another purpose? Gonna have to go see if I have one now!
-Bruce
1971 K5 Blazer 4WD
Old 01-21-2019, 08:11 PM   #12
jjzepplin
jjzepplin's Avatar
Yup. I got one of them somewhere. I am not using it. It's in a bucket somewhere in the garage.
Old 02-02-2019, 06:40 PM   #13
Blazerowner
So to bring this back up my lines do not have a junctuon block where yours is shown at the soft brake line connection. I do have a junction but it is right next to the front crossmember and not bolted to anything. One like shoots back to the driver soft line and one line goes across the crossmember to the passenger soft line. This is how my old lines were and how the new lines hook up. I think this is stock but could be wrong.
Kirk
66 Nova
Old 02-02-2019, 06:41 PM   #14
Blazerowner
Here’s reference I used for my ORD steering support. It shows the junction block just like I have.
http://67-72chevytrucks.com/vboard/s...d.php?t=694692
Kirk
66 Nova
Old 02-02-2019, 08:05 PM   #15
1rippen6
His is a 69 so it is probably just the way Chevrolet did the first year. I know the clips for the fuel and brake lines on a 70 are different then a 71 and 72.
1rippen6 is offline   Reply With Quote
Old 02-02-2019, 09:12 PM   #16
Blazerowner
You’re probably right. I didn’t think about the spread in years.
Kirk
66 Nova
Old 02-02-2019, 09:30 PM   #17
rsavage
rsavage's Avatar
My 70 K10 short bed fleet was the same as the 69 Blazer. Can't remember the 71 Blazer but it had front disc brakes (first year for discs) so that was probably the change?
1961 C1 Corvette
2021 Durango RT 5.7
