05-18-2018, 11:34 AM | #1 |
Reseal a used 700R4?
I swear I've sen this but I cant find it, so here goes.
The trans in the 87 R10 is having issues. Late on the first 1-2 shift of the day, TCC goes in and out when she gets hot and it likes to weep a little in the front - I'm thinking front seal and those pesky shaft rings. Truck is probably not worth the price of a rebuilt trans. Picked up a 4L60 (700r4), out of a 92 C10, 15k on a supposed GM rebuild. K case turned 2wd. Truck it was in was totalled but driveshaft was not bent and trans case appears fine. Trans has set in the garage for about a year. To use it I need to swap some wiring (TCC on diesel is pressure / speed controlled not ECM controlled), TV cable (diesel is different length) and governer. My question is, since it has been sitting and I ahve it out, what seals shoudl I replace? Pan, filter, and governer reseal are on the list. What about front and rear, and possibly dipstick seal? Or should I just throw it in and drive it? As always, thanks for your support.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by truckdude239; 05-18-2018 at 08:05 PM. |
05-18-2018, 01:34 PM | #2 | |
Re: Reseal a used 70rings.0R4?
replace the items you mentioned above...if you don't, there is always that chance of a leaker...no one wants a trans that leaks... Good Luck !!!!! |
05-18-2018, 07:31 PM | #3 |
driving is in my blood
Diesels have a lower stall on the converter too don't forget.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-29-2018, 01:26 PM | #4 |
Re: Reseal a used 700R4?
I believe the VB is calibrated differently as well, so be careful swapping things around to a non-gas trans.
