Old 05-22-2018, 12:45 PM   #1
desert-rat
Drop spindle or lowering springs. 2"
I know lowering spring throw off the geometry and drop spindles keeps everything the same. But what's the pros, cons to both?? Is a camber kit or something like that needed for lowering springs?? Trying to save some money here.
Willing to buy drop spindles if anyone has a pair for sale. Thanks.
desert-rat is offline   Reply With Quote
Old 05-22-2018, 05:43 PM   #2
Mike C
Mike C's Avatar
Re: Drop spindle or lowering springs. 2"
2" springs don't cause any issues IME. Chances are won't even change your alignment.
When you want to go more than 3" drop (or even 3" on some trucks) you need to go with Spindles combined with springs. If you have a drum brake truck and you want to go lower than 3" you need to do disc conversion using drop spindles..
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-22-2018, 10:32 PM   #3
County
I just went through the same debate. Technically drop spindles keep all the factory geometry, but for only 2" I went with the ECE 2/4" deluxe spring drop. Spindles not worth the extra hassle for me and with minimal drop everything should align just fine.
County is offline   Reply With Quote
Old 05-23-2018, 09:21 AM   #4
old51sedan
old51sedan's Avatar
I'm getting ready to do the 2" drop spindles and 4" drop in the rear also. Do you have any pictures as to how yours came out? Did you use a rear shock relocating kit and/or use a shim to align the drive shaft?
old51sedan is offline   Reply With Quote
Old 05-23-2018, 09:54 AM   #5
67c10rustbuket
67c10rustbuket's Avatar
Both require an alignment.
No camber kit required (its not a Ford). But make sure you go to a competent alignment shop that can align a classic and knows what alignment shims are.
Spindles require disk brakes if not a 71-72, or already converted.
Spindles may require a wheel change. Original drum brake wheels may interfere and some 15” wheels (depending on offset) may hit the lower control arm.
Spindles give you a guaranteed drop.
Springs give you a questionable amount of drop based on original specs. Example, your original coils have likely sagged 1” from 50 years of use so a 2” spring may only give you 1” drop.
If you decide on spindles, make sure you buy drop spindles for your year. IE don’t buy ‘72 spindles if you have a ‘68 or else you will have to replace ball joints, tie rods, and center link.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-23-2018, 10:40 AM   #6
County
ECE deluxe comes with shock relocators and adjustable panhard bar to recenter rear axle. I still have about 2 1/2 inches between top of tires and fender. Kind of centers wheel all the way around. I still haul stuff, so super low isn't my thing.
Old 05-23-2018, 02:41 PM   #7
hotwls13
That looks GREAT!
I plan to go 2/4 on my 70 GMC 1/2t. Just looked up Early Classic, they are in Fresno, CA. They don't have a storefront anymore but they will work with me if I wanted to pickup my parts (I'm in Bakersfield about 1.5hr drive away).
I get to Fresno several times per Year. Might work out perfect.
How hard was the install??
hotwls13 is offline   Reply With Quote
Old 05-23-2018, 03:40 PM   #8
gearheadperkins
gearheadperkins's Avatar
beautiful truck.. and nice stance..
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 05-23-2018, 05:24 PM   #9
County
Install wasn't terrible. I was by myself and not in a rush, knocked it out in a couple days. On a frame off deal, might only be a few hours.
50 yr old bolts are the enemy. Hit all bolts with PB Blaster every day for 2-3 days prior, and put in New rear coil hardware on reassembly. Lowes has the grade 8 stuff.
Worst part was the shock rivets for the relocation brackets. I took a grinder and cut a big slot in the middle of the rivet head. Also go get a couple new drill bits to finish drilling them out. PITA, but they come out eventually. I even had one stretched enough I wrangled my sawzall up there and zipped it right off.
After that, smooth sailing.
Thanks for the compliments.
Old 05-24-2018, 08:25 AM   #10
old51sedan
old51sedan's Avatar
Thanks for the reply and the pictures, your truck looks nice, just what I'm looking for on my truck. I will be doing the 2 1/2" drop spindles, I have the 4" drop springs for the rear along with the new axles, new 5 holes drums and have shims ordered to align drive shaft. Did you have to install a new adjustable pinhead bar? I will be installing a set of 5 lug rally wheels when done.
Old 05-24-2018, 10:56 AM   #11
County
Yes sir, new adjustable panhard bar. I probably didn't HAVE to with the 4" rear, only offset rear axle less than a half inch. Came in the kit though. It's all nice stuff, but it would have been even nicer if the bar had 2 adjustable ends instead of just one, but once it's done, it's done. No biggie.
I just put a cargo strap from one frame rail to opposite side axle and cinched it in until I had same measurement on each side, adjusted bar to that length, and bolted it on.
Old 05-25-2018, 08:59 AM   #12
old51sedan
old51sedan's Avatar
Thanks for your reply, my truck sits way to high for me. I bought a new one in 69 and I don't remember it sitting this high, maybe I'm just getting a little older. Either way, its getting lowered with disk brakes and ralleys.
Old 05-25-2018, 11:23 AM   #13
6T7 C10
For a 2" drop I would keep it simple with springs and replace any loose or worn components. You do lose some of the travel vs dropped spindles but under regular driving conditions do not think you would notice. I was under the impression that some dropped spindles push the width out wider due to how they are made and that would also change geometry.
6T7 C10 is offline   Reply With Quote
Old 05-25-2018, 07:10 PM   #14
plastercracker
mine has 6 inch rear drop coils in rear and new adjustable track bar. front has 3 inch drop springs and 2 1/2 cpp drop spindles. have to move front brake hose brackets and make new shock mounts. put c notch in but dont think i really needed it. Name:  100_3283.jpg
plastercracker is offline   Reply With Quote
Old 05-27-2018, 02:05 AM   #15
Z10
Z10's Avatar
2.5 Spindles + 4" lowering blocks=full suspension travel. Pic of my 72
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 06-01-2018, 02:33 PM   #16
desert-rat
Thats a clean drop.
Old 06-01-2018, 02:35 PM   #17
desert-rat
You all with rear coils make it easy to lower. Im trying to lower my rear leafs.
Old 06-02-2018, 01:30 PM   #18
OARNGESI
OARNGESI's Avatar
Just convert to trailing arms itís a easy swap or a flip kit is pretty good just probably end up lower than you want
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
