02-13-2014, 03:14 PM | #1 |
Sheet metal the inside of Bed panels?
I'm putting repro bed panels on my 72 blazer.. I'm eventually gonna Line-X the interior..but was wondering if anyone has welded sheet metal on the insides of the bed panels as apposed to the vinyl wrapped plywood?.. Since I'm in the body stage.. I think this would be a cleaner look...but I don't see any out there..so maybe there's a reason why?...also thinking of cutting speaker holes before they are welded to panels.....
1972 Chevy Blazer Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=560741 |
02-13-2014, 03:55 PM | #2 |
Re: Sheet metal the inside of Bed panels?
Welding is kind of permanent. With panels, you can remove them and make changes pretty easily.
02-13-2014, 06:54 PM | #3 |
Also depends on if you have a double or single wall top doesnt it? Dont you have to access the top hold down bolts from the bottom (from behind the panels if you have them)
02-14-2014, 09:36 AM | #4 |
hmm.. didn't think of that.. although I think with the custom old school roll bar I'm putting on it.. it not be able to put a top on it.. The original design was to make it a permanant convertable..so I wasn't worried about the height of the roll bar... (Line-X, Marine grade seats, radio, drain plugs..etc..) however the more I go along..the more I think I may wanna have a top on it eventually.. guess I'll measure the roll bar height which will determine which way to go from here... thanks for that information.
02-14-2014, 04:36 PM | #5 |
I made panels out of diamond plate - the diamond plate fits in the original upholstery bracket at the top, and then I attached to some L shaped metal brackets I installed on the bottom. I assume you could use any type of metal panel. One thing I added right after installing is sound deadening material to eliminate any rattling.
1972 GMC Jimmy, ZZ4 350 |
02-14-2014, 04:47 PM | #6 |
Here are some pictures I dug up.
02-14-2014, 06:41 PM | #7 |
When you said you used diamond plate, I was kinda doubtful about how it would look. But it looks wicked! Nice job.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
02-15-2014, 03:37 AM | #8 |
Collector of Projects
I am covering the Blazer in Line-X as well.. If I decide to build bed side covers, it will be out of the material they build boats; marine-grade high-density polyethylene. It can be routered, screwed and glued just like wood (special glue.) Perfect material for the Blazer. Comes in a couple different colors or could be upholstered to match the rest of your interior.
http://www.kingplastic.com/products/...king-starboard |
02-15-2014, 07:32 AM | #9 |
Our Home Depot has 4' x 8' sheets of Aztex Plastic sheet in white about 1/2" thick not the same as what you were looking at but pretty nice stuff. Probably made from recycled polypropylene $99..... cuts and routers easily.
02-16-2014, 12:55 AM | #10 |
((((((CWSOHM))))))
Wooooweeeee that's sexy I'm liken that bud ! I like the speaker cut outs too. WeLL Done ! |
