01-27-2019, 10:21 PM | #1 |
Junior Member
Method for white roof cab
What is the best procedure for painting cab when it is going to have white roof and upper door frames?
Would you apply white base, let flash, mask and apply other base color and clear all at once? Would you apply white base and clear it; scuff and mask it for other base color; then clear over everything? |
01-27-2019, 10:48 PM | #2 |
Post Whore
Re: Method for white roof cab
I would do the white first(less to tape)...then tape it off and spray the rest...then clear all at once
01-28-2019, 07:54 PM | #3 |
Junior Member
Thanks mongocanfly. That's what I was thinking but I have never taped on fresh base. Don't know how tricky that will be.
01-28-2019, 09:41 PM | #4 |
Post Whore
Wait till its dry ...real dry.... before you tape it....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-06-2019 at 06:09 PM. |
01-30-2019, 01:25 PM | #5 |
I would use an intercoat clear to protect your base before taping. There's just too much to risk if your tape adhesive decides to bleed into the base.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
02-06-2019, 06:06 PM | #6 |
When removing the tape from new paint, don't pull directly away from the panel, peel the tape back over itself. Less chance for it to pull the paint off.
