02-07-2019, 01:25 AM | #1 |
Blast cabinet on cast aluminum?
Looking for advice from those of you that have experience with this. I have several items like a cast intake and some brackets that I want to look new as cast. What have you found to be the best media for this? Thanks
02-07-2019, 09:01 AM | #2 |
Re: Blast cabinet on cast aluminum?
Glass beads.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
02-08-2019, 05:11 PM | #3 |
I have used silica sand with good results. The coarseness of the finished product might be too much for some tastes depending on how rough it was to begin with. Walnut shell should give a softer finish, but I have not actually done that. I would not blast any gasket surfaces or threads with silica or glass when cleaning aluminum and would avoid blasting then at all even with shells or husk media. A couple layers of masking tape will protect those surfaces so long as you do not blast down on the tape, a little grazing will be fine, but not for prolonged moments.
Certainly start with lower air pressures and work you way up to equalize the finish and your patience. Disclaimer: I assume when you say "cast" you mean that the parts have a very dull/rough surface to begin with and not anywhere near polished.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-08-2019, 10:15 PM | #4 |
Glass beding will make it look like new and won’t hurt the gasket surface I do it all the time don’t use sand it will etch the aluminum
