Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 09-26-2017, 01:17 AM   #1
Stooch
!988 Silverado 1500 front brake upgrade
Can I install heavy duty front calipers and rotors on my Standard duty truck? If so does anything need to be modified?
Stooch is offline   Reply With Quote
Old 09-26-2017, 07:59 PM   #2
mountie
mountie's Avatar
Re: !988 Silverado 1500 front brake upgrade
I have an '88 C2500. You should be able to find some, no problem.
Rotors can be updated & fit like your original, and calipers are same.
Good front brakes require the rears to be good & properly adjusted.
Replace all 5 flex brake lines with SS braided. ( Russell is a good brand)
( I was born in Victoria BC .... BTW )
'70 GTO Midnight Blue
'88 GMC Sierra SLE Camper Pkg 392,000 & still going!
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'96 Honda 550 - Beautifully original
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
mountie is offline   Reply With Quote
Old 09-27-2017, 01:22 AM   #3
Stooch
Thanks Mountie. I will look into finding the parts and changing lines.
Old 09-27-2017, 08:07 AM   #4
mountie
mountie's Avatar
To finish the upgrade, do what I did ( learned from this great forum)..
Get a 2002 Chevy Tahoe master cylinder. There is an adapter fitting for the forward brake line on the MC. It will give you a firm brake peddle, whereas, the original is soft. You'll love the improvement!
( don't worry about that 'elec. plug-in' on the side of the 2002 reservoir.... that's for newer vehicles with a 'low fluid sensor'.
Old 09-27-2017, 03:08 PM   #5
Stooch
Thanks for the new info Mountie.
Old 09-27-2017, 03:33 PM   #6
Tom
driving is in my blood
Tom's Avatar
No rotors needed. HD 3/4ton calipers and pads fit 1/2ton and LD 3/4ton rotors just fine.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Old 09-28-2017, 06:34 PM   #7
arrg
Stooch, do you have a C1500 or K1500? If you have a c1500 with the LD brakes (1" thick rotors vs the 1.25" thick) the upgrade path includes swaping your spindles and rotors. You have to have the 1.25" rotors to use the 3/4 ton calipers. I ran into this on my 88 C1500.
arrg is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
