Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-04-2017, 02:21 PM   #1
C.20
C.20's Avatar
99 tahoe 5.7 Cant figure out the problem
Hows everyone doing so my 99 Tahoe 5.7 recently overheated on me when i was idling then went away as i drove looked in the radiator there was not much coolant check the oil it wasn't milky need help trying to figure it out heard people saying it could be intake manifold gasket or a water pump but few days ago i got to work turned the truck off and it started gargling. anything helps thank you
Smoke Tires Not Drugs
C.20 is offline   Reply With Quote
Old 10-04-2017, 03:34 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 99 tahoe 5.7 Cant figure out the problem
It was gargling because it was low on coolant and air was passing through the heater core
Fill the cooling system and pressure test it. Then look for leaks.
Intake gaskets are common, radiators are common. It could be plastic fittings leaking if you have rear heat. It could be a lot of things. Its 18 years old. If it is the intake gaskets, replace them with the updated set.
-99 K2500 LS CCSB 7.4
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable, 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is online now   Reply With Quote
Old 10-04-2017, 03:54 PM   #3
C.20
C.20's Avatar
ALso if I sit for a long time at a light it hesitates then itís fine wonít have a problem when I drive no smoke comes out if I stop and idle it smokes and my injectors are also bad to so I donít no whatís going on I got all the gaskets I might just replace everything
Old 10-14-2017, 09:05 PM   #4
chipmaker
mine was running out of coolant. my tech found small leak from intake gasket. seems like its a common issue. better catch it before it leaks inside as well as out.
1997 Tahoe
2017 Mustang GT
04 and 15 Harleys
chipmaker is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
