Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 09-13-2017, 11:09 AM   #1
lucky_7
lucky_7's Avatar
Lowered 97 ext cab 2", bottoming issue
Hey guys,
A few weeks ago I installed the belltech lowering shackles on my 97 gmc. I really like the look to the truck, but, I now have a bottoming issue I cant seem to find. I'm worried its the shocks running out of travel. The passenger side shock looks like it has plenty of room, but the driver side looks to only have 3-4" left before bottom. Any suggestions on new shocks that would be the correct length?
lucky_7 is offline   Reply With Quote
Old 09-14-2017, 03:37 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Lowered 97 ext cab 2", bottoming issue
2" lowering with no weight in the bed is no different then a stock truck with weight out back going down the road. The stock shocks should not bottem out before the bumpstops hit.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Old 09-19-2017, 03:11 PM   #3
lucky_7
lucky_7's Avatar
Makes sense but why the big bang now, truck has never had a rough ride. Now its like speedbumps are everywhere...Ill have to do some more looking. Maybe I have a busted shock?
Old 09-19-2017, 07:36 PM   #4
Tom
Tom's Avatar
I seem to recall some clearancing needed to run shackles on my 78, perhaps its something along those lines with yours? Is the shackle moving and contacting something? Otherwise I'd look for something broken like you said. My truck is 6" low in the rear with shock extenders and no issues. The extenders added 4" so my shocks are always 2" compressed like yours, going on 11yrs now.
Old 09-20-2017, 09:37 AM   #5
SCOTI
SCOTI's Avatar
Agreed. Check to make sure the shackles are not hitting the bed support bracing under the floor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 09-20-2017, 07:29 PM   #6
Cape Codder
Cape Codder's Avatar
I have 2" shackles on my truck and with three people in cab and my boat trailer hooked up the shackles hit the bed floor. Sounds worse than it is.
Cape Codder is offline   Reply With Quote
Old 09-20-2017, 10:28 PM   #7
Kudzupatch
Kudzupatch's Avatar
If you have an exposed shaft, put a zip tie around the shaft of the shock, near the shock body. Go for a drive and once it "bottoms out" stop and see where the zip tie is. If it is the shock it will be at the top of the shaft. If not you will see just how far the shock compressed
Kudzupatch is offline   Reply With Quote
Old 09-21-2017, 03:17 PM   #8
lucky_7
lucky_7's Avatar
Thanks guys, Ill take another look tonight. So far I haven't found any marks, dents, scuffs, or tell tail signs on something hitting.
Old 09-22-2017, 04:23 PM   #9
Tom
Tom's Avatar
Heck just have someone jump up and down in the bed while your looking.
Old 09-22-2017, 04:49 PM   #10
lucky_7
lucky_7's Avatar
I found it, Its the leaf spring clasp/tie. Not sure what you call it. The thing that holds all the springs together. Anyway it hits the bottom of the bed. Odd that nobody else has this problem..
Old 09-23-2017, 12:01 PM   #11
LT7A
That's a new one to me. I have 2" drop shackles (LMC) and no interference. Mine's a 4x4 that I don't beat on and wanted to tighten up the tire to fender gaps (the shoe test for MCM fans). But the 4x4 started out higher in the first place.
Is your rear spring arching negatively for the clamp to hit the bed, or is it catching on the corner where the bottom of the bed meets the bed side? I'm trying to picture how that part hits.
Old 09-23-2017, 01:46 PM   #12
lucky_7
lucky_7's Avatar
This is the clearance between the back spring and the bed cross support. Both sides hit. Speedbumps are definalty not my freind...
Old 09-29-2017, 03:11 PM   #13
LT7A
I see what you mean. I doubt that thing is terribly essential unless it ties in somehow to the lower spring. You could consider cutting off the two upper arms of the clamp where they are above the spring. It appears they're not doing anything up there anyway. I assume they are attached underneath and not held on by clamping action or they'd be rattling all over the place with that spring pack.
Old 10-02-2017, 03:25 PM   #14
lucky_7
lucky_7's Avatar
I think they are intended to help with rebound, the top of the clip is supposed to keep the top leaf from separating from the other leafs, leaving it by itself to absorb rebound.
I found this:
http://www.suspensionspecialists.com/tech0004.html#9
Now, this raises the question, should I fix the spaced clip? According to the website in the link above, there should only be about a 3/32 between the top of the top leaf, and the clip.
Old 10-06-2017, 02:15 AM   #15
CH3VY1972
CH3VY1972's Avatar
I would notch the bed support, and reinforce it by welding some 1/8" plate. Even if it may seem that the spring clip isnt doing much... it could cause other issues. I could be wrong but notching would be logical imo
The one and only
|CH3VY1972|
1970 c10 i6 short stepper (sold)
1972 c20 lwb sb 350
1979 silverado 10 lwb (parts rag)(sold)
1990 K1500 4x4 swb.
CH3VY1972 is offline   Reply With Quote
Old 10-06-2017, 01:37 PM   #16
Tom
Tom's Avatar
I've never heard of someone doing that, the reinforcing that is. Even belltech in their instructions for installing shackles tells you to cut the bed support but no reinforcement.
Old 10-06-2017, 01:58 PM   #17
CH3VY1972
CH3VY1972's Avatar
I'm a fabricator what can I say
The one and only
|CH3VY1972|
1972 c20 lwb sb 350
1990 K1500 4x4 swb.
Old 10-11-2017, 07:04 AM   #18
Terrick down Under
Terrick down Under's Avatar
X2 on the "reinforce " the notch even in the bed rail.
Terrick down Under is offline   Reply With Quote
Old 10-18-2017, 09:39 AM   #19
lucky_7
lucky_7's Avatar
Thanks guys, I will give it a try.
Old 11-02-2017, 08:43 AM   #20
lucky_7
lucky_7's Avatar
Ive been thinking. What if i installed the front leaf spring shackles, would that drop the angle of the spring back to normal. I know the rear of the spring is higher, but maybe the angle would help. If so, ill add the front spindles for an overall 2/4 drop and that would be all I wanted...
Copyright ©2000 - 2018, vBulletin Solutions Inc.
