05-06-2013, 07:09 PM | #1 |
67 Nova wont start but has power, Help!
Electrical is not my strong suite
So I was out autox my nova for the hell of it and got a lil sideways and went off into the cornfield and it was still running just fine but when I parked it and turned it off, I couldnt get it to crank again. I was able to jump it by just going undernieth it and crossing the starter pos and neg with a wrench to make it back home but I cant use the key to start it. The wires look fine, nothing looked riped out when I went offroading but a lot of loose dirt was kicked up haha. I will try and take some pics of it. But any ideas where to look? It has a 69 C10 350 in it pretty much all stock and a TH350. Thanks
1968 C10 LWB 6.0 LSx swap. Thorley LT swap headers, TH400 cheapy jegs 3k stall, 224/228 .600 lift mild cam. comp Ni beehive springs/Ti push-rods: dyno'd 319RWHP/417RWTQ through stock truck intake, stock 317 heads, 12 bolt 3.73, and 6lug wheels! running and driving great but still more plans for it. Last edited by Cannon007; 05-06-2013 at 07:19 PM. |
05-07-2013, 04:26 AM | #2 |
Re: 67 Nova wont start but has power, Help!
Maybe an issue with the Neutral Safety Switch?
Try moving the shifter around while holding the key to start. |
05-14-2013, 01:51 AM | #3 |
no not that. I got it starting again, just checked all the wiring and removed and repluged it in and it apparently worked cause im good now pfft!
1968 C10 LWB 6.0 LSx swap. Thorley LT swap headers, TH400 cheapy jegs 3k stall, 224/228 .600 lift mild cam. comp Ni beehive springs/Ti push-rods: dyno'd 319RWHP/417RWTQ through stock truck intake, stock 317 heads, 12 bolt 3.73, and 6lug wheels! running and driving great but still more plans for it. |
