07-11-2017, 01:51 PM | #1 |
P0300 code
During a family road trip my check engine light came on so I ran the code and it came back as P0300 random misfire. I filled up at a shady place so I figured maybe I got some water in my tank. Ran a can of sea foam through it and it cleared it but came back shortly after.
Truck couldn't possibly be running any better. No missing, sputtering etc. From what I read this code is hard to diagnose because it doesn't give you a specific cylinder as a starting point. I hate to just start throwing parts at a truck that runs so good. Anyone have any tips....
1969 GMC K2500 |
07-11-2017, 05:15 PM | #2 |
Re: P0300 code
Plugs and wires is what I would start with
07-11-2017, 08:58 PM | #3 |
Re: P0300 code
That's what I'm leaning toward.
1969 GMC K2500 |
07-12-2017, 07:15 AM | #4 |
Re: P0300 code
How many miles are on your truck? And does the engine actually feel like it is misfiring? Or does it still run smooth? The 99-06 trucks have been known to throw the po300 after 120,000+ miles because the timing components wear, but the crankshaft position sensor still reads to the factory specs. This causes it to think there is a misfire under long driving times, or under heavy load. I went through this with my Silverado. The engine runs amazing at 170k miles with no sign of misfire. I'm not saying that this is definitely your issue, plugs and wires wouldn't hurt. But if it is the same issue, you'll have to go in with a scan tool and do a re-learn on your crankshaft position sensor. Hope this helps.
'83 GMC K2500 Suburban 4x4
2000 Chevrolet Silverado 1500 Z71 4x4 God Bless America!!!! |
07-12-2017, 10:18 AM | #5 | |
Re: P0300 code
The light just went back out since I got back home yesterday and did some in-town driving. I'll have to do a little research on the re-learn and see what I come up with.
1969 GMC K2500 |
07-12-2017, 10:28 AM | #6 |
Re: P0300 code
I just bought this cool little gadget made by Foseal on Amazon. It plugs into your obd2 plug and you use your phone to read the codes and clear them as well. A little research on Youtube and I found the leaking vacuum hose.
Not sure about your issue but I like this little thing and it cost about $17.99.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-12-2017, 10:41 AM | #7 | |
Re: P0300 code
