Old 05-09-2013, 09:45 PM   #1
FLYNAVY30
Factory engine questions
Hey guys, my 72 should be arriving from KY on Saturday night. I was originally intending to swap in in LS motor, but as many of you have pointed out, at least from the pics, the thing looks so clean, itd almost be a shame to remove the rebuild factory motor.
My question is, what motor is it exactly. Ive read both 400 and 402? Were these factory small blocks or big blocks? Mine is a 3/4 ton C20.
Lastly, has anyone done any real hot rodding to their factory motor? I was thinking if I decided to keep it, a nice aluminum head/intake/cam and EFI upgrade with an overdrive trans might be a nice middle ground for a daily driver.
Any feedback is greatly appreciated...Ill post more pics Saturday night!
FLYNAVY30 is offline   Reply With Quote
Old 05-10-2013, 09:00 AM   #2
vectorit
What?
vectorit's Avatar
Re: Factory engine questions
Does your truck still have the SPID label on the glove box?
If it does, it should say what engine it came with from the factory.
If it does not, then try looking at the front pass side block deck in front of the head to see if it has your VIN.
The 400 small block is a 4.125-inch bore, and has steam holes between the cylinders and that have matching holes in the cylinder heads.
400's are good engines, just as long as the cooling system is free of sludge. Since the ones that I have seen that are suffering from clogged cooling, tend to run hot and cause head gasket failures.
There are big blocks called 400's as well, but technically they are 402 cubic inch engines. It was a weird marketing thing GM did, where they badged the cars/trucks with a 400 emblem. But the engine was just a 396 that was bored .030 over.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-10-2013, 11:01 AM   #3
Bigdav160
Bigdav160's Avatar
From the pictures in the other thread, there is a big block in the engine bay.
If it was mine, I would hesitate to do anything irreversible.
If (collectable) Chevrolet trucks follow the trend set by early Corvettes, Chevelles and Camaros; a factory born-with engine is highly desirable.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-14-2013, 10:35 PM   #4
70cst
70cst's Avatar
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
