Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-19-2020, 01:51 AM   #1
BigRandy
BigRandy's Avatar
74 C10 Blower Motor all On or all OFF
My 74 C10 with factory air has a problem with the blower.
With the fan on low the blower is off but when set to any other speed it runs wide open. Is this a known or common problem? The speed selector feels normal so I'm thinking there might be a relay between the switch and motor. I can pull and test the switch. Just thought I'd ask first.
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 10-19-2020, 02:50 AM   #2
kglowacky
Re: 74 C10 Blower Motor all On or all OFF
there's a blower motor speed resistor in the engine compartment bolted to the ac evaporator cover. that's where i would start. when they go bad it acts like what you are describing.
kglowacky is offline   Reply With Quote
Old 10-19-2020, 11:32 PM   #3
Greasey Harley
Greasey Harley's Avatar
I just fixed the blower on my '73 Jimmy by cleaning the contacts on the resistor with a wire brush and adding Di-electric grease to the connections.
Then I took the dash apart and hosed out the heater switch with electronics cleaner.
works perfect now; high-medium-low (no off)
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 10-20-2020, 06:00 AM   #4
BigRandy
BigRandy's Avatar
Perfect!
Thank you guys for the tips. I'll get on it ASAP
