10-26-2018, 07:34 PM | #1 |
headlight trouble on 65 c10
I am almost done with my 65 c10. I was finishing up some stuff today on it. One of the headlights did not work on high beam so I thought I would change it with another headlight I had laying around. I did and then neither headlight would work on low or high. So I put the other one back in with the same result. The ground was a little loose so I changed the plug with a good one and still nothing. I then ran a ground wire from the battery to the headlight and with it just hanging by the harness both came on. I re installed the headlight and nothing but the passenger side works on high only. I have a new under the dash harness,dimmer switch, and headlight switch. Any ideas?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
10-27-2018, 07:13 AM | #2 |
Old member
Re: headlight trouble on 65 c10
Well you answered your own question. If they both worked with the added ground then it's a ground issue. Take them back out and check the light connector on each light and the tabs of each light. With the light unplugged take a test light and check the connector to see if they have power.
Going by what you said they should but the ground maybe not making good connection.
