11-25-2015, 02:07 PM | #1 |
Factory big block throttle, return, and PCV
Does anyone have a picture of an original PCV setup for a big block (1970 if it matters)?
Mine uses a straight PCV, not a 90, so the hose sticks way up and the wraps around to the carb; that's how it was when I got it, and the truck was largely unmolested except for carb linkage. Also, does anyone have a good picture of the clip used to hold the throttle rod to the carb? I've just got a cotter pin through it and suspect that's not original. Same deal with return spring. I guess I'm asking "Does anyone have a good photo of a stock big block" with these details visible?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-25-2015, 02:48 PM | #2 |
Re: Factory big block throttle, return, and PCV
these are a 72 so they sound different than yours.
72 Cheyenne Super 80 Silverado Blazer 2wd |
11-25-2015, 03:15 PM | #3 |
throttle rod to carb is just held in with a small cotter pin
1967custom |
11-26-2015, 05:02 AM | #4 |
Here's some pics of my 69. the throttle linkage is retained by a split pin. On mine anyway.
John 69 c20, 396, th400, dana60, ps, ac |
11-26-2015, 11:06 PM | #5 |
The correct pcv hose has a molded 90* angle so it works correctly with the straight pcv. Split cotter pin is correct for bob linkage, return spring attaches to kick down bracket at rear of carb- should be a hole that the springs attach to. The throttle rod was the reason for the stop lifts equipped on many of the pre 71 trucks, the motor mounts would break on driver's side pinning throttle wide open and causing a wreak. Hence the reason to transition to cable in 71.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-27-2015, 02:38 PM | #6 |
So to reassert what I think I've heard, for my 1970:
- Split pin/ cotter-pin correct, maybe with a washer - Single spring from linkage to lift hook in front of carb Any idea on single/double, style, color, or pic of the return spring?
