Old 04-22-2018, 10:06 PM   #1
ebernst
What is the hole in the top center of the cab on my 1953 Chevy 3100?
I'm wondering what the hole is for, and if it is factory. On the inside, there is what appears to be a hard rubber gasket of some sort, while the outside on the exterior of the cab it appears to be a rivet some sort. Does anyone know what this is, and what's the purpose?
Here's my 1953 Chevy 3100 Build Thread and here's my website Classic Nation.
ebernst is offline   Reply With Quote
Old 04-22-2018, 10:13 PM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: What is the hole in the top center of the cab on my 1953 Chevy 3100?
Probably a CB antenna.
PDW HOTRODS is offline   Reply With Quote
Old 04-23-2018, 12:11 AM   #3
dsraven
haven't seen that except for an antenna of some sort.
Old 04-23-2018, 12:19 AM   #4
mr48chev
mr48chev's Avatar
That one may have been for a business two way radio. CB antennas usually didn't have that grommet that seems to have gone along with the old business or other 2 ways.
My 71 GMC has a hole dead center in the middle of the outer skin for a radio with the cable routed between the inner and outer skin. That's not going to be a fun fix.
My ongoing truck projects:
Old 04-23-2018, 01:40 AM   #5
dsraven
either way, to repair, clean it down to bare clean steel before attempting to weld a plug in the hole. if you can't find a plug the right size then get one bigger diameter and same gage and use a step drill to make the hole fit the plug. nice clean bare steel that way too. you can use a weak magnet to hold the plug in there nice and flat with the roof, tack it, remove the magnet (magnets tend to distort welding current and cause porosity in the weld), body hammer with dolly under to get the plug flat after slight warpage from the weld process, then another tack across from the first when it is cooled off, same same with the hammer/dolly, tack again, cool same same. soon the plug will be welded all the way around. a flap disc will easily flatten the weld bead down but be very careful not to heat the roof up. take lots of time to allow the roof to cool everywhere or you will spend more time getting the roof normal looking than you would have spent waiting for the weld and grind process to cool off. looks like sand blasting or dipping may be in your future anyway so, good luck with the project.
Old 04-23-2018, 02:42 AM   #6
jjzepplin
jjzepplin's Avatar
My 70 has some holes from the siren it used to have from being a fire trail rig.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-25-2018, 10:47 PM   #7
G&R's57GMC
G&R's57GMC's Avatar
My Tahoe has 2 of those where the fire dept. antennas were.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 04-27-2018, 12:29 PM   #8
_Ogre
_Ogre's Avatar
breaker breaker 19!
shop air compressor timer
