Old 10-17-2017, 01:00 PM   #1
LBJ
2004 Vortec 5.3 Oil Pressure Sending Unit?
I suspect my oil pressure sending unit may be going crazy, so want to replace it. First, since I don't have any service manuals, I need to know where the unit is.
It's a 5.3 LS style (Vortec) gas engine in a 2004 Silverado 1500 4WD.
Anyone got a photo? Or link to a shop manual?
Thanks, LBJ
LBJ is offline   Reply With Quote
Old 10-17-2017, 01:46 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 2004 Vortec 5.3 Oil Pressure Sending Unit?
right at the back of the intake manifold where its located on a smallblock...this is a ls3 but they're all in the same location that I've seen on LS...
Old 10-17-2017, 05:34 PM   #3
LBJ
Good photo. Kinda have to crawl over the engine to get to it though. Ha. Many thanks. LBJ
Will a regular deep socket fit over that? Hate to buy a special socket for that one thing.
Old 10-17-2017, 07:38 PM   #4
mongocanfly
Post Whore
I used a socket to get mine out but I don't remember the size
Old 10-17-2017, 09:03 PM   #5
clinebarger
1-1/16" socket, Your lucking a standard socket will fit '03/'04/'05/'06 truck sending units as earlier & newer require specialty sockets! Now it may require a thin wall chrome as a impact socket may not clear the valley cover (Gen 3 engines are different than the Gen 4 shown in the pic).
clinebarger is offline   Reply With Quote
Old 10-26-2017, 02:29 PM   #6
LBJ
I got the new part and socket and looked at the engine. Wow, I couldn't get my right hand in past the harness and some other tube in the way. In fact, I can barely see the top of the harness to the oil pressure sensor. If I could get past the things in the way, I might be able to feel my way down to remove the wiring and change it out. right now, guess I'll have to stay with the one that's in the block.
Old 10-27-2017, 03:35 PM   #7
wahl4m
make sure the area is free of oil & debris -that might fall in sending unit hole ! ive seen instances where something has fallen in hole !!
wahl4m is offline   Reply With Quote
Old 10-27-2017, 05:40 PM   #8
LBJ
I have looked at the unit every which way, and cannot get to it without removing some of the cables, harnesses, etc, that are in the way. I also looked at the PVC valve and tried to remove it - it acts like it was installed with a hydraulic ram! I even tried using pliers to pull it out of the seat. Nothing doing.
Old 10-28-2017, 12:00 AM   #9
68c10airstream
68c10airstream's Avatar
LBJ, I believe that once you remove the sender look down inside the hole and i think there is a small screen that gets varnished/plugged up, but gm sell a new one. This screen issue can make a perfectly working sender indicate wrong because oil pressure gets blocked/plugged.
68c10airstream is offline   Reply With Quote
Old 10-28-2017, 08:36 AM   #10
LBJ
Unfortunately, I cannot get to the pressure sensor to remove it (much less see it) without some fairly complicated disassembly of fuel lines and wiring harnesses etc. Guess I'll have to live with the sensor that's in there now. Just not a major problem at this point. Thanks for the tip though.
Old 10-28-2017, 10:26 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Not sure if I understood it correctly but I seem to recall reading where someone converted the oil cooler block off plate to install a sending unit.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-28-2017, 12:12 PM   #12
LBJ
Not sure where the oil cooling block-off is either. I have purposely left this engine alone for 13 years other than change the oil and filters. Been running fine till now so I hated to mess with perfection. Ha
A couple of pics. You can see the fuel line and several other lines in the way. Pretty tough to get behind the engine. That big hump at the end of the intake manifold doesn't help any. On the passenger side, I tried a reach around and no way there either. I suppose I could start taking the fuel line apart and getting it out of the way, but don't want to open a can of worms on the fuel injection system.
Old 10-28-2017, 03:46 PM   #13
95 S_Trucker
95 S_Trucker's Avatar
It's more feeling than seeing. You can get to it without unhooking any fuel lines or harnesses. The only thing you need to unplug is the electrical connector at the sending unit. Then slip the socket on. Then an extension. Then a ratchet. You'll mostly be working from the drivers side.
95 S_Trucker is offline   Reply With Quote
Old 10-28-2017, 03:50 PM   #14
95 S_Trucker
There is not a pcv valve on your engine either. There is a fixed orifice in the valve cover. Take the pcv valve back and return it.
Old 10-28-2017, 05:28 PM   #15
LBJ
Cannot even get my hand down there to "feel" my way thru. Just no way - too much crap in the way. Haven't bought a PCV valve yet, just checking to see if it needed replacing. Ha
Old 10-28-2017, 05:29 PM   #16
Old Money
i had an 05 5.3 k1500. i took plastic cover off top of engine and laid a sleeping bag on top of engine. i crawled on top of engine with 3/8 ratchet 5 inch extension and socket.i looked down and saw oil sending unit and 2 minutes later i had it changed. old money.
Old Money is offline   Reply With Quote
Old 10-28-2017, 05:50 PM   #17
mongocanfly
Post Whore
mine had one on it ...looks like this...its right above the oil filter. ..
Old 10-28-2017, 06:31 PM   #18
95 S_Trucker
Try to go beside the drivers side of the intake manifold. I have large hands and can feel them.
Old 10-28-2017, 08:23 PM   #19
LBJ
I've been right on top of the driver's side of the engine. Just cannot get my hand thru the mess of lines, much less hold a ratchet. Everything's pretty solid on all those cables and such. If I knew what would happen if I disconnected the fuel line, that would be cool. But, I don't want to get a fuel feed problem started. You know, introducing air into the line. I know very little about fuel injection systems, owned all carbed cast iron engines up till now except for 2 C5 Corvettes (99 and 01). Never had to mess with them at all.
Old 10-28-2017, 08:28 PM   #20
mongocanfly
Post Whore
pulling the fuel line will cause no issues..just use the tool
Old 10-28-2017, 08:49 PM   #21
95 S_Trucker
And depressurize the fuel system. Remove the fuel cap and the fuel pump relay. Attempt to start the truck. Crank it a few more times. Use a rag to catch fuel when you unhook the line. Like previously stated, use the fuel line disconnect tool.
Old 10-29-2017, 07:13 PM   #22
LBJ
Is the fuel line disconnect tool something that is widely available? Like Auto Zone or O'Reillys? I'll do a search.
Old 10-29-2017, 07:25 PM   #23
mongocanfly
Post Whore
yep...our local oreillys has them in their loanatool section...comes in a set with different sizes
Old 10-29-2017, 07:34 PM   #24
LBJ
OK, good. I just watched a You Tube video on how to do the job. Just never worked on these LS/Vortec engines yet. Ha. I may be able to get to the sensor with that fuel line pulled out of the way. Glad it's not that tough to do. Thanks all!
Old 10-30-2017, 06:51 PM   #25
LBJ
Good news, I changed out the oil pressure sensor. Bad news is it didn't change anything! ha. Still hits 70PSI when the engine is cold while accelerating and stays between 40-50 PSI in normal driving. Oh well, at least I got the job done. The fuel line disconnect tool worked fine. Was able to get the old sensor out by feel mostly, and get it all put back together successfully. Thanks to all the help here, I appreciate it. I did order a code reader from Rock Auto to see if any more codes have been set. It will be here in a few days.
